creating threads in solids
thedoctor
  • 12 years later...
I have tried to get solid sweep to work to cut threads I don't know how many times. Every time I try that I get the Parasolid® Kernal Interface Error: PK Error Code:999 - Geometry fails to pass checks. I have tried this at work and at home and I always get the same results. It doesn't work in the top of the front view now matter what I try.
Ok. Wow, I think I finally figured out why. I was looking at Scott's example and saw that his triangle was closer to the size of the actual thread cut. I think I was drawing my triangle too big and it was overlapping on the OD face of the thread. Does that make sense? I figured this out by creating a swept surface and saw that my threads were fine on the ID, but the OD face was overlapping itself. I offset the outer face of my triangle in to be a diameter .02" larger than the OD of the bolt I was making and voilà!
^^ If you make your triangle (60deg lathe tool) tool large, it "intersects" itself with each revolution, thus erroring out.
If you throw a big chamfer on the nose of the bolt first, then sweep the threads it looks very nice.
Sidebar- Try bringing in sw file with history tree and look how hole wizard threaded holes are created. Very cool. Basically a positive bolt is in there, then a boolean remove to make the id threads.
