O/D Turning in X4
Hey guys.
I'm new to this forum so hopefully I describe my problem in the correct way
I have roughed a long stem with numerous diameters to about 0.050" above size to allow for stress relief.
I now want to machine to finish size but I can only add a rough stock size as stock recognition. Is there a way of telling mastercam that I want to start at 0.050" above all diameters and not one generic rough size?
Thanks in advance
Lathe Rough between any two boundaries.
Try this…
I did this using X7, but I believe that it was the same in X4.
Do an XForm - Offset Contour to create the rough stock boundary.
Now when you go to chain a Lathe Rough toolpath, note the sequence –
If prompts you to ->
“Select the entry point or chain the inner boundary.”
Select your finish boundary and end that chain.
Now it prompts you to ->
“Select the outer boundary or select the retraction point or select done.”
Select your rough stock boundary.
This will do Z axis roughing passes, without cutting to much air.
If you want to “follow” the profile when removing this material you can do that using a Lathe Finish toolpath by setting the Finish stepover and the Number of finish passes.
(On the Finish Parameters tab a page).
