Incorrect cycle time in Active Report
Bill Henderson
I have done a search on here but couldn't find anything.
I have some drilling cycles that put out some crazy times.
In verify the run time is approximately correct.
I have made my own report and most other cycle times are correct in the report except for these odd ball drilling cycles.
I uploaded my report and if you look at Operation 8 it is one hole thru a 3/4" plate Feed rate 5 IPM with .10 pecks.
I am wondering if I have something askew.
Thanks for any insight.
Dawoo DMV3016.pdf
Hi Mick,
Here is what the XML has... and for some reason it is picking LONG
-<NCFILE>
<SPACER>SJV</SPACER>
<NCIFILE-LONG>C:\USERS\BILLHENDERSON\DOCUMENTS\MY MCAMX8\MILL\NCI\BASE PLATE OP1.NCI</NCIFILE-LONG>
<NCIFILE-SHORT>BASE PLATE OP1.NCI</NCIFILE-SHORT>
<NCFILE-LONG>C:\USERS\BILLHENDERSON\DOCUMENTS\MY MCAMX8\MILL\NC\BASE PLATE OP1.NC</NCFILE-LONG>
<NCFILE-SHORT>BASE PLATE OP1.NC</NCFILE-SHORT>
-<OPERATION>
<NAME>Peck Drill</NAME>
<COMMENT>DRILL 3/16 DOWEL</COMMENT>
<IMAGE>C:\USERS\PUBLIC\DOCUMENTS\SHARED MCAMX8\COMMON\REPORTS\IMG\OPERATION7.BMP</IMAGE>
<COOLANT>Flood</COOLANT>
<CLEARANCE-PLANE>1.0</CLEARANCE-PLANE>
<COMP2TIP>NO</COMP2TIP>
<DEPTH>-0.85</DEPTH>
<FEED-PLANE>0.1</FEED-PLANE>
<PROG-NUM>0</PROG-NUM>
<RETRACT-PLANE>0.0</RETRACT-PLANE>
<STOCK-TO-LEAVE>0.0</STOCK-TO-LEAVE>
<TIME-LONG>1 HOURS, 9 MINUTES, 41 SECONDS</TIME-LONG>
<FEEDRATE>5.1792 inch/min</FEEDRATE>
<SPINDLE-SPEED>2158 RPM</SPINDLE-SPEED>
