Update NCI
Dolan
The Chook that Im writing requires me to parse the current NCI(ASCII). How can I make sure the current operations are written to that file? If its a new part, that hasn't been saved yet, I'd want it written to T.NCI (with no prompt to overwrite). That seems to be MCs default scratchpad. For instance, if I wanted a "one off quickie". I wouldn't want to save the MC7 file, but I would need the NCI. The only func Ive found that seems remotely close is:
void write_prm_to_nci (void);
Is this writing to the binary NCI? I rather not got the binary route. Im guessing its quite cold, damp & dark in there smile.gif
Also, how can I check the db to see if there are actually any operations to output to the NCI?
All I really need is a current NCI to parse, to proceed. NC utils|Edit NCI is doing basically what Im looking for, as far as updating the NCI.
To post all operations to your current post settings us the
nci_bin n;
boolean ok;
long fpos;
nci_manager (0, NCIMGR_POST_ALL, &n, &fpos, &ok)
Also, the 1016 line contains the operation id # which can be used to check against the operation list. To see if all operations have been posted, make a list of operation id #'s from the operation list:
ulong *op_ids = NULL, n_op_ids = 0;
op_list *opl = op_list_ptr;
while (opl != NULL)
++n_op_ids;
op_ids = (ulong *) REALLOC (op_ids, n_op_ids * sizeof (ulong));
if (op_ids == NULL) break;
op_ids[n_op_ids - 1] = opl->op.op_idn;
opl = opl->next_ptr;
Then compare the operation id # from the 1016 line to your op_ids and look for a match. If any of your op id #'s from the 1016 line aren't found in your op_ids list, then it has not been posted.
Don't forget to free up the op_ids with a
FREE (op_ids);
