Active Reports- adding maximum Z depth to tool list
tony1001
I have modified the Active Reports Tool List (MILL-SIMPLE).rpx file to look like the picture, but in that last column I can't figure out (if possible) how to get it to put out a maximum Z depth for the tools. I tried putting in MAX-Z in the "DataField" and also where it says "Text," but it just stays blank. Basically, what I'm after in that column is if I have 3 operations that use the same tool, is there a way to get it to output the deepest Z point among those 3 operations?
Make sure you are pulling the Z out of the Operation and not the tool
-<OPERATION>
<SPACER>SJV</SPACER>
<NAME>8 - Helix Bore</NAME>
<COMMENT>3/8 FEM / MILL HOLDING BORE INTO JAWS / -1.042</COMMENT>
<COOLANT>Flood</COOLANT>
<DEPTH>-1.0425</DEPTH>  <<<<<<<<------------------------From here
<PROG-NUM>5897</PROG-NUM>
<STOCK-TO-LEAVE>0.0</STOCK-TO-LEAVE>
<TPLANE-PLANE-NAME>5897</TPLANE-PLANE-NAME>
<TPLANE-PLANE-NUMBER>4</TPLANE-PLANE-NUMBER>
<CPLANE-PLANE-NAME>5897</CPLANE-PLANE-NAME>
<CPLANE-PLANE-NUMBER>4</CPLANE-PLANE-NUMBER>
<WCS-PLANE-NAME>5897</WCS-PLANE-NAME>
<WCS-PLANE-NUMBER>4</WCS-PLANE-NUMBER>
-<TOOL>
<COMMENT>3/8 ENDMILL</COMMENT>
<CORNER-RADIUS>0.0</CORNER-RADIUS>
<DESCRIPTION>#1 - 0.3750 ENDMILL1 FLAT - 3/8 ENDMILL</DESCRIPTION>
<NAME>3/8 ENDMILL</NAME>
<DIAMETER>0.375</DIAMETER>
<DIAMETER-OFFSET>1</DIAMETER-OFFSET>
<LENGTH-OFFSET>1</LENGTH-OFFSET>
<MATERIAL>Carbide</MATERIAL>
<NUMBER>1</NUMBER>
<TYPE>Endmill1 Flat</TYPE>
<ASSY-NAME>.500 LOC - 1.12 OUT OF HOLDER</ASSY-NAME>
<HOLDER-NAME>DEFAULT HOLDER</HOLDER-NAME>
<HOLDER-LIB>NA</HOLDER-LIB>
</TOOL>
Yes, there are two places to find tool information in the setup sheet. Under TOOLS and under OPERATION. You want to use the fields that are under OPERATION:
SETUPSHEET/NCFILE/OPERATION/TOOL/MIN-Z  (minimum z i.e. max depth)
SETUPSHEET/NCFILE/OPERATION/TOOL/MAX-Z (opposite - usually clearance plane or retract plane)
I have been messing with this for a while now, but I'm still missing something. Where should I look to make sure that it is pulling the Z depth from the OPERATION instead of the TOOL? I tried copying the subreport so that there is one that has a recordset pattern that says //TOOL for the first 6 columns and the other subreport has a recordset pattern that says //OPERATION for the Max Z depth column. If I preview it, the Max Z depth column shows the -.5 from the XML file, but if I do the report from the tool manager in Mastercam, the column is still blank.
Can you check to make sure there is a value in the XML file? Or post the XML here and we can take a look.
Post the setup sheet
Open this folder: %my mcamx9%\common\reports\XML
Look for the newest *.xml file
By the way, you can see an example of how to do what you are asking by looking at this template I published a while back: http://www.emastercam.com/board/topic/83094-free-activereports-template-for-setup-sheets/
Here is what comes up in the XML file:
B112.xml
I see there is no section for operations, and I'm not sure how to add it. Under Data source, it is set to go here C:\Users\Public\Documents\shared mcamx9\common\reports\SST\Samples\Mill\SSM.xml, using the sample file that comes with Mastercam in that folder.
I tried to upload the tool list files, but I get an error saying I'm not permitted.
I'll check out your link when I have a chance, my internet access is limited.
  • 11 months later...
I see this topic is almost 12 months old but I also have a problem with my tool z depths and the set sheet.
Similar to the above set sheet, I too am posting MAX Z depth. This works fine for all tools on OP1 in TOP plane.
As soon as I flip too bottom plane and posted set sheet the MAX Z depth is still using TOP plane. I then changed T & C plane to bottom while leaving Shifted OP2 plane as is, this then worked.
All was well so I thought.
OP3 is front view, rotated 180 deg and set to op3 plane. Nothing I try can give me the correct MAX-Z value. It gives my TOP view Y value.
Any ideas would be much appreciated.
