Remove Decimal Point From B Rotation
Hi guys,
could anyone point me in the right direction please. I am trying to remove decimal point from B Axis Rotation.
Using modified V18.00 P0 E1 W18.00 T1450384971 M18.00 I0 O1 - # Post Name           : MPMASTER on a Hitachi Seiki HS500 Horizontal , Indexer
T1 M06 (2"  FACE MILL)
G00 G17 G90 G54 X-2.675 Y0. S6000 M03
B0.
G43 H1 Z1. M08 T2
Z.1
should be
B0
G43 H1 Z1. M08 T2
I am looking at # Common User-defined Variable Initializations (not switches!)
AND # Format statements - n=nonmodal, l=leading, t=trailing, i=inc, d=delta
Hi guys,
B0.
G43 H1 Z1. M08 T2
Z.1
should be
B0
G43 H1 Z1. M08 T2
You are close, but need to look for the B fmt statement and change the format value to one that will output what you are looking for.
Normally it resides here:
# Toolchange / NC output Variable Formats
fmt  "T" 4  t$          #Tool No
fmt  "T" 4  first_tool$ #First Tool Used
fmt  "T" 4  next_tool$  #Next Tool Used
fmt  "D" 4  tloffno$    #Diameter Offset No
fmt  "H" 4  tlngno$     #Length Offset No
fmt  "G" 4  g_wcs       #WCS G address
fmt  "J" 4  j_wcs       #WCS J address yasnac extended workoffsets
fmt  "P" 4  p_wcs       #WCS P address
fmt  "S" 4  speed       #Spindle Speed
fmt  "M" 4  gear        #Gear range
fmt  "N" 4  n$          #Sequence number
fmt  "X" 2  xabs        #X position output
fmt  "Y" 2  yabs        #Y position output
fmt  "Z" 2  zabs        #Z position output
fmt  "X" 3  xinc        #X position output
fmt  "Y" 3  yinc        #Y position output
fmt  "Z" 3  zinc        #Z position output
fmt  "A" 11 cabs        #C axis position
fmt  "A" 14 cinc        #C axis position
fmt  "A" 14 cout_i      #C axis position
fmt  "A" 4  indx_out    #Index position
fmt  "R" 14 rt_cinc     #C axis position, G68
fmt  "I" 3  iout        #Arc center description in X
fmt  "J" 3  jout        #Arc center description in Y
fmt  "K" 3  kout        #Arc center description in Z
fmt  "K" 2  lead        #Helical lead
fmt  "R" 2  arcrad$     #Arc Radius
fmt  "F" 15 feed        #Feedrate
fmt  "P" 11 dwell$      #Dwell
fmt  "M" 5  cantext$    #Canned t
Change to one of these:
#Default english/metric position format statements
fs2 1   0.7 0.6     #Decimal, absolute, 7 place, default for initialize (
fs2 2   0.4 0.3     #Decimal, absolute, 4/3 place
fs2 3   0.4 0.3d    #Decimal, delta, 4/3 place
#Common format statements
fs2 4   1 0 1 0     #Integer, not leading
fs2 5   2 0 2 0l    #Integer, force two leading
fs2 6   3 0 3 0l    #Integer, force three leading
fs2 7   4 0 4 0l    #Integer, force four leading
fs2 8   5 0 5 0l    #Integer, force five leading
fs2 9   0.1 0.1     #Decimal, absolute, 1 place
fs2 10  0.2 0.2     #Decimal, absolute, 2 place
fs2 11  0.3 0.3     #Decimal, absolute, 3 place
fs2 12  0.4 0.4     #Decimal, absolute, 4 place
fs2 13  0.5 0.5     #Decimal, absolute, 5 place
fs2 14  0.3 0.3d    #Decimal, delta, 3 place
fs2 15  0.2 0.1     #Decimal, absolute, 2/1 place (feedrate)
fs2 16  1 0 1 0n    #Integer, forced output
fs2 17  1.4 1.3lt   #Decimal, absolute, 4/3 trailing
If one does not exist create the one you need.
