Posting M99 instead of M30
I am trying to find a way I can change the output of "M30", to allow me to choose between a M99 or M30.
I would like it to default to M30, but I would like to be able to tell it to use M99 instead of M30 if I am looping a program, or using it as a subprogram.
I am using the mplmaster post (x5), slightly modified for my machine.
I used the post debugger and found this, I am just unsure of what to add or replace to make it  user definable:
peof$            #End of file for non-zero tool
      ptoolend$
      comment$
      n$, "M30", e$
      mergesub$
      clearsub$
      mergeaux$
      clearaux$
      "%", e$
Is something like this even possible?
As little as I use M99, I just hand replace M30 with M99. If I wanted to do what you want, then I would make a copy of the post you are using, rename it, then edit
      ptoolend$
      comment$
      n$, "M30", e$
      mergesub$
      clearsub$
      mergeaux$
      clearaux$
      "%", e$
Change to this ;
      ptoolend$
      comment$
      n$, "M99", e$
      mergesub$
      clearsub$
      mergeaux$
      clearaux$
      "%", e$
Then to control usage, just use the M99 post with the same machine and control definition as the post you have been using
My reasoning for doing this is I like my mastercam programs to be a post and go.
I don't want any manual editing. If I am ever not there I don't want someone to have to be responsible to edit the program.
I ended up using misc integers. I have it working very nicely.
Thanks for everyone's tips and advice, I appreciate it.
Also about the block skip. For some reason it doesn't work on my machine. (Fanuc ot Control) I have the button but it doesn't seem to enable the block skip feature.
On some machines it is an option. Yes I have seen some builders charge for it over the years.
