Print cotation mark character
Hi everyone!
I'm a newbe in Mastercam and this is my first post here.
I need a post processor for a Sinumerik and so I'm editing a mpmaster post for me. It has been fun, I learned a lot with this (now I know what's a nci file!), but is difficult because I use to program gcode, java and C and this is a strange language...
for now I have one question that really bothers me:
- I want to print a special charater, the cotation mark " but I can't find enougth documentation on the web.
I need to print the tool name instead of the tool number, but the name must be inside cottation marks
example:
T1 M06; CENTERDRILL
must be:
T "CENTERDRILL" M06
in java or C is printf("T\""%s"\"", toolName);
btw... for now I have made the header and footer, tool change and CYCLE81 drill cycle
where can I find documentation? this is not easy and without documentation is really hard core...
many thanx in advance and congrats for your forum =D
my CYCLE81 (so far...)MCALL CYCLE81(50.,0.,3.,-20.)X9.634 Y14.106X32.685 Y-22.708X-11.526 Y-31.825X-14.794 Y20.815X-23.912 Y34.061X-78.272 Y29.073MCALL
CYCLE81 (RTP, RFP, SDIS, DP, DPR)
RTP – Return plane or Retraction plane (absolute)
RFP – Reference plane (absolute)
SDIS – Safety distance (enter without sign)
DP – Final drilling depth (absolute)
DPR – Final drilling depth relative to reference plane (enter without sign)
this is different from fanuc's G81... in reallity there's no G98/99 option in nci code, you must check if the last Z pos and retract value are the same to set the G98/G99 option in G81 cycle.
my RTP equals to initht$ (cleance or last Z)
my RFP equals to drl_sel_tos$ (top of stock)
my SDIS equals to abs(drl_sel_tos$-drl_sel_ref$)
my DP equals to depth$
you don't need the DPR since you have the DP.
I'm not use to work with SINUMERIK, I'm learning this also =D
ok problem solved.
use the number 34 for " output.
my result:
pbld, *n$, "T-"spaces$ = 034,*strtool$,34spaces$ = sav_spc"M06", ptoolcomm, e$
output:
N100 T-"CENTERDRILL 12" M06 ;CENTERDRILL 12
note: sav_spc is used to store de default spaces$, defined in the control file. in this case I need two formatations, one space and no spaces between words. Because mastercam uses this variable(spaces$) to compose lines with words, if space$=0, the code will come out with no spaces. The "T" statment and 34 statment are treated as words, so if spaces$=1 the result is T- " toolName " instead of T-"toolName".
If spaces$=0 the whole line will be N100T-"CENTERDRILL 12"M06;CENTERDRILL 12 and could be different from the rest of the code, deppending of the spaces definition on control file.
To avoid this you can set the sapce$ to zero, use your code and then reset the spaces$ to default, and then the rest of the code.
any doubt or error found tell me please =D
The MP language has been enhanced over the years, so that using the ASCII Literal "34" is no longer necessary.
To output a double quote character, you now enclose the string in "single quote characters".
smy_string : 'This string contains "double quote" characters.'
That will let you use double quotes for string output.
Another trick; instead of continually manipulating the 'spaces$' variable to control spacing, leave "spaces$ = 1", and use the 'no_spc$' parameter to delete the individual spaces between "parameters" on the output line.
Also, note that because 'strtool$' is a string variable, there is no need to "force" output with the asterisk (*) character. It will always be forced. Only numeric variables respond to the (*) character...
     '"', no_spc$, strtool$, no_spc$, '"', e$
