Generic 5 axis shift_90_s
Just wanted to make sure, but if my rotaxis/rodir look like this
#Primary axis angle description (in machine base terms)
#With nutating (mtype 3-5) the nutating axis must be the XY plane
rotaxis1$ = vecx #Zero vecx
rotdir1$ = vecy #Direction vecy
#Secondary axis angle description (in machine base terms)
#With nutating (mtype 3-5) the nutating axis and this plane normal
#are aligned to calculate the secondary angle
rotaxis2$ = vecz #Zero vecz
rotdir2$ = vecx #Direction vecx
Then my  shift_90_s should be a -1 one correct?
#Secondary shift (determines position and angle calculation)
#plane correction 90 degree shift case (plus or minus)
#used when secondary plane is defined perp to primary zero
#EX. P - vecx, vecy S - vecz, vecy
shift_90_s : -1 #Shift pos.=1, neg.=-1
Also was wondering if there was a way using the generic 5 axis post or mastercam to force my secondary axis to go to the negative side.
i.e. instead of rotating to C0, A30. Rotate to C180, A-30.
Not sure when I would ever use this. Was just curious if it was possible.
Thanks!
