flowline paths
botty
I recently stated programming bent fuel pipes around 3" dia. This is relatively easy on Mastercam 9.1sp2. However to achieve the flowline I have to recreate the customers parasolid model to reflect the path required.
I have just got to this stage on the another pipe and came up to a problem. The flowline path started at the highest point (uppermost Z) The toolpath finshed one half then revisited to finish the other. Is this because of where the surface starts and finishes?
Can I manually alter the start and finish?
This pipe is round surely I should be able to dictate it beginning and end after the creation of the surface ie when I need to put a cutterpath on it eek.gif .
Hi Botty, easy one here, you should have seen your flowline data when you applied your toolpath and choose the offset (because flowline consider the normal of your surface), the cut direction, the step direction and the start (up or down) if you already have the operation done, go in the operation manager and expand you flowline geometry by clicking the little + and you'll see flowline data and play with it. HTH!
Simon
