Overrride ARC Feed Rate in 2018
Hello everyone,
     I am now using 2018 and I am having problems when turning on "Overrride ARC Feed Rate".  There are two issues:
1.  If FEED RATE and PLUNGE RATE are the same and "Overrride ARC Feed Rate" is on, the post does not show any feed rate
2. If FEED RATE and PLUNGE RATE are different and "Overrride ARC Feed Rate" different, the post only shows feed rate for FEED RATE and PLUNGE RATE but not the "Overrride ARC Feed Rate"
Please help, I tried to use * on the FEED but worked very weir codes.
Thank you for your help.
===== Different FEED RATE and PLUNGE RATE, "Overrride ARC Feed Rate" is on =====
O1327(50-1327-32C OP2.NC)
N16( 1.0000,1.5" SHELL MILL, CB, USED TOOL,)
(2FLTS .500LOC, 2.10LOH)
(HELITANG-T490 FLN D2.00-5-.75-R-13)
G0 G17 G40 G49 G80 G90
G91 G28 Z0 M19
G28 Y0  (ID FEEDRATE DECREASED FROM F50. DOWN TO F12.5)   =========> IT SAID HERE, BUT NOT OUTPUTTING
(OD FEEDRATE INCREASED FROM F50. UP TO F31.25)                      =========> IT SAID HERE, BUT NOT OUTPUTTING
T16 M6(ROUGH AND FINISH 6X PART FACES, CUT#72)
G90 G54 X-2.95 Y0.
S4500 M3
G43 H16 Z1. M8(DOC= Z0.)
Z.1875
G1 Z.102 F30. =========> PLUNGE FEED RATE
X-2.25 F50. =========> START FEED RATE
X10.25
X10.95
G0 Z.227
Y2.996
Z.1875
X10.25 F50. =========> START FEED RATE
X-2.25
X-2.95
G0 Z.227
Y0.
Z.1645
G1 Z.079 F30. =========> PLUNGE FEED RATE
X10.25
X10.95
G0 Z.204
Y2.996
Z.1645
X-2.25
X-2.95
G0 Z.204
Y0.
Z.1415
G1 Z.056 F30. =========> PLUNGE FEED RATE
X10.25
X10.95
G0 Z.181
Y2.996
Z.1415
X-2.25
X-2.95
G0 Z.181
Y0.
Z.1185
G1 Z.033 F30. =========> PLUNGE FEED RATE
X10.25
X10.95
G0 Z.158
Y2.996
Z.1185
X-2.25
X-2.95
G0 Z.158
Y0.
Z.0955
G1 Z.01 F30. =========> PLUNGE FEED RATE
X10.25
X10.95
G0 Z.135
Y2.996
Z.0955
X-2.25
X-2.95
G0 Z.135
Y0.
Z.0725
G1 Z0. F30. =========> PLUNGE FEED RATE
X10.25
X10.95
G0 Z.125
Y2.996
Z.0725
X-2.25
X-2.95
G0 Z1.
M9
G91 G28 Z0.
/G28 Y0. M5
G0 G90 G54 X0.
M30(1,555CHARS - 1.56KB)
===== Same FEED RATE and PLUNGE RATE, "Overrride ARC Feed Rate" is on =====
G91 G28 Z0 M19
G90 G54 X-2.95 Y0.
S4500 M3
G43 H16 Z1. T15 M8(DOC= Z0.)
Z.1875
G1 Z.102   =========> No FEED RATE here, FEED RATE must present here
X-2.25
(CUTTING...)
X-2.25
X-2.95
G0 Z1.
M9
G91 G28 Z0.
/G28 Y0. M5
M1
===== My Post Codes =====
#Region Motion NC output
# Motion NC output
#The variables for absolute output are xabs, yabs, zabs.
#The variables for incremental output are xinc, yinc, zinc.
prapidout       #Output to NC of linear movement - rapid
      sav_gcode = gcode$
      if convert_rpd$ = one,
        gcode$ = one
        feed = maxfeedpm
        ipr_type = zero
    #"DEBUG: ", ~mr3$, ~nextop$, e$
      if tool_op$ = 19, "M0(AGAINST PIN STOP HERE)", e$
      pcan1, pbld, n$, [if prv_sgplane <> sgplane, sgplane], `sgcode, [if prv_sgplane <> sgplane, sgabsinc], pccdia, [if gcode$ = 1, sgfeed]
        pxout, pyout, pzout, pcout, [if gcode$ = 1, `feed], strcantext, scoolant, e$
      gcode$ = sav_gcode
plinout         #Output to NC of linear movement - feed
      pcan1, pbld, [if prv_sgplane <> sgplane, sgplane], `sgcode, [if prv_sgplane <> sgplane, sgabsinc], pccdia, #, n$, sgfeed
        pxout, pyout, pzout, pcout, `feed, strcantext, scoolant, e$
pcirout         #Output to NC of circular interpolation
      if not(arccomp), pcompwarn, pHelixBoreCompWarn
      if full_arc_flg$,
        if plane$ = zero, result = force(xabs,yabs)   #force coordinate on full arc
        if plane$ = one,  result = force(yabs,zabs)   #force coordinate on full arc
        if plane$ = two,
          result = force(xabs,xabs)   #force coordinate on full arc
          result = force(zabs,zabs)   #force coordinate on full arc
      if hel_2100 = one, pcirout2
      else, pcirout1
pcirout1        #Output to NC of circular interpolation
      pcan1, pbld, [if prv_sgplane <> sgplane, sgplane], sgcode, [if prv_sgplane <> sgplane, sgabsinc], pccdia, #, n$, `sgfeed
        pxout, pyout, pzout, pcout, parc, feed, strcantext, scoolant, e$
pcirout2        #Output to NC of circular interpolation
      if (plane$ = zero & fmtrnd(zinc)<>0)
       | (plane$ =  one & fmtrnd(xinc)<>0)
       | (plane$ =  two & fmtrnd(yinc)<>0), phelout
      else, pcirout1
phelout         #Output to NC of helical interpolation
      if errorcheck = one, [if not(arccomp), pcompwarn, pHelixBoreCompWarn]
      if plane$ = zero,
        result = nwadrs(strk, lead)
        lead = abs(zinc/sweep$*360)
      if plane$ = one,
        result = nwadrs(stri, lead)
        lead = abs(xinc/sweep$*360)
      if plane$ = two,
        result = nwadrs(strj, lead)
        lead = abs(yinc/sweep$*360)
        pxout, pyout, pzout, *lead, pcout, parc, feed, strcantext, scoolant, e$
#EndRegion
# Error Checks
#Region pOverRideARCFeedRate
       if OverideArcFeedRateIO = 1 & MaxIDDecreaseFeedRate > 0, "(ID FEEDRATE DECREASED FROM", *feed, "DOWN TO", *MaxIDDecreaseFeedRate, no_spc$, ")", e$
       if OverideArcFeedRateIO = 1 & MaxODIncreaseFeedRate > 0, "(OD FEEDRATE INCREASED FROM", *feed, "UP TO", *MaxODIncreaseFeedRate, no_spc$, ")", e$
#EndRegion
#Region Tool change common blocks
ptlchg_com      #Tool change common blocks
#Region Null tool change
ptlchg0$         #Call from NCI null tool change (tool number repeats)
#Region  Define Number Constants
OverideArcFeedRateIO: 0
MaxIDDecreaseIO : 0
MaxODIncreaseIO : 0
MaxMaxIDDecreaseFeedRate : 0
MaxIDDecreasePerCent : 0
MaxODIncreaseFeedRate : 0
MaxODIncreasePerCent : 0
fmt ""   4 OverideArcFeedRateIO
fmt ""   4 MaxIDDecreaseIO
fmt ""   4 MaxODIncreaseIO
fmt "F"  2 MaxIDDecreaseFeedRate
fmt      2 MaxIDDecreasePerCent "%"
fmt "F"  2 MaxODIncreaseFeedRate
fmt      4 MaxODIncreasePerCent "%"
#Region pparameter
pparameter$ # Run parameter table
if prmcode$ = 15965, OverideArcFeedRateIO = rpar(sparameter$, 1)
if prmcode$ = 15089, MaxIDDecreaseIO = rpar(sparameter$, 1)
if prmcode$ = 15093, MaxODIncreaseIO = rpar(sparameter$, 1)
if prmcode$ = 15966, MaxIDDecreaseFeedRate = rpar(sparameter$, 1)
if prmcode$ = 15968, MaxIDDecreasePerCent = rpar(sparameter$, 1)
if prmcode$ = 15967, MaxODIncreaseFeedRate = rpar(sparameter$, 1)
 if prmcode$ = 15969, MaxODIncreasePerCent = rpar(sparameter$, 1)
