MR9$ and MR10$ in POCKET - WEAR
Hello everyone,
   I am currently using MAKINO CELL SYSTEM which does not allow user to manual input the H WEAR and COMP WEAR at the control.   So, so I am trying to write the post of which using G10 for H Wear and COMP.
   I am almost there but not 100% there because of the pocket feature as COMPUTER - WEAR.  I am trying to call out the "WEAR" from POCKET and failed.  I also debugged it but not successful.  Would you guys please tell me what I've done wrong?
PS: Please screen images
Thank you.
================ G-CODES ================
O1302(10326 MWM2400-2500-25 REVA- OP1.NC)
DEBUG =  opcode$ 4. op_id$ 6. tool_op$ 3.  ============> I debugged this in POCKET toolpath as COMPUTER
N3( .2500,1/4 EM, CB, USED TOOL,)
(3FLTS .625LOC, .75STO)
G0 G17 G40 G49 G80 G90
G91 G28 Z0 M19
G28 Y0
T3 M6(FINISH POCKET, CUT#10)
G90 G54 X0. Y0.
S8500 M3
(.0875 STEPOVER, 1X, .005 FINISH)
G90 G10 L11 P3 R.0002(H WEAR) ======> GOOD CODE
G43 H3 Z1. M8(DOC= Z-.69)
Z.0625
G1 Z-.69 F25.
X.011
G3 X-.0547 R.0328
X.0985 R.0766
(CUTTING...)
Y-.025
G3 X-1.2999 Y-.0625 R.075
G1 X-1.2124 Y-.214
G0 Z1.
G90 G10 L11 P3 R0.(H WEAR 0) ======> GOOD CODE
DEBUG =  opcode$ 4. op_id$ 99. tool_op$ 3.============> I debugged this in POCKET toolpath as WEAR
N302(FINISH POCKET, CUT#11)
G90 G10 L11 P3 R.0002(H WEAR)======> GOOD CODE
G90 G10 L13 P3 R.0001(COMP)" ==========> MISSING, IT SHOULD APPEAR HERE
T3 M6( .2500,1/4 EM, CB, USED TOOL,)
G0 G90 G54 Z5.
X0. Y0. S8500 M3
G43(D3)H3 Z1.(DOC= Z-.69)
(.0875 STEPOVER)
Z.0625
G1 Z-.69
X.011
G3 X-.0547 R.0328
(CUTTING)
X-1.31 Y.6496
Y-.025
G1 G40 X-1.2124 Y-.214
G0 Z1.
G90 G10 L11 P3 R0.(H WEAR 0)======> GOOD CODE
G90 G10 L13 P3 R0.(COMP 0)" ==========> MISSING, IT SHOULD APPEAR HERE
M9
G91 G28 Z0.
/G28 Y0.
M5
G0 G90 G54 X0.
M30(4,415CHARS - 4.43KB)
============== Post ================
#Region pHWearReset
pHWearReset
  if mr9$ <> 0,
    g10tool = tloffno$ #assign current tool number
    if g10tl_len <> zero | g10tl_len = zero,
      pbld, no_spc$, "G90", "G10", "L11", *g10tool, "R0.", spaces$ = 0, "(H WEAR 0)", spaces$ = sav_spc, e$
      !mr9$
     if g10tl_len <> zero & g10tl_dia = zero, g10mode = one #Length Only
     if g10tl_dia <> zero & g10tl_len = zero, g10mode = two #Diameter Only
     if g10tl_len <> zero & g10tl_dia <> zero, g10mode = three #Both length and diameter are active
#EndRegion
#Region pCompReset
pCompReset
 "DEBUG = ", ~opcode$, ~op_id$, ~tool_op$, e$
if (mr10$ = 0 | mr10$ <> 0),
  if not(op_type_hsm) & opcode$ = 4,
    if g10tl_dia <> zero | g10tl_dia = zero,
      pbld, no_spc$, "G90", "G10", "L13", *g10tool, "R0.", spaces$ = 0, "(COMP RESET 1000)", spaces$ = sav_spc, e$
      !mr10$ = 0
      if (g10tl_len <> zero | g10tl_len = zero) & g10tl_dia = zero, g10mode = one #Length Only
      if (g10tl_dia <> zero | g10tl_dia = zero) & g10tl_len = zero, g10mode = two #Diameter Only
      if (g10tl_len <> zero | g10tl_len = zero) & g10tl_dia <> zero, g10mode = three #Both length and diameter are active
#EndRegion
#Region pHwear
pHwear
 if mr9$ <> 0,
     pbld, no_spc$, "G90", "G10", "L11", *g10tool, *g10tl_len, spaces$ = 0, "(H WEAR)", spaces$ = sav_spc, e$
     !mr9$
#EndRegion
#Region pCompActive
pCompActive
 if comp_type = two & tool_typ$ > 9 & (mr10$ <> 0 | mr10$ = 0),
     pbld, no_spc$, "G90", "G10", "L13", *g10tool, *g10tl_dia, spaces$ = 0, "(COMP)", spaces$ = sav_spc, e$
     !mr10$ = 0
#EndRegion
#Region pCompActive2
pCompActive2
 if mr10$ <> 0 & not(op_type_hsm) & cc_pos$ > 0,
     !mr10$ = 0
  mr10$ = 0
#EndRegion
#Region Null tool change
ptlchg0$         #Call from NCI null tool change (tool number repeats)
      pcom_moveb
      pcheckaxis      #Check for valid rotary axis
      comment$
      pHWearReset ============> Call out to here
      pCompReset ============> Call out to here
      "(*)", e$ # Second star, end of toolpath
      if nextdc$ <> 13, *ToolSequenceNumber, no_spc$, #No Tool Change
        if mr3$ = 1,
          if nextdc$ <> 13, spaces$ = 0,  ptoolcomment , spaces$=sav_spc #No Tool Change
        spaces$ = 0, scomm_str, *scomm_sav, ", CUT#", *sToolPathNumber, scomm_end, spaces$=sav_spc, e$
        if MaxRoughDepth > 0 & (opcode$ = 1 | opcode$ = 2 | opcode$ = 4 | opcode$ > 16), NumberOfRoughDepthCuts = (abs(operation_depth)+ abs(BreakThroughAmount))/MaxRoughDepth
      #if not(tool_op$ = 18), pMultiPass
      #if tool_op$ = 18, pCircleMill
      #pbld, no_spc$, "G43", pfzout, #NO TOOL CHANGE
      if cinc, pbld, "G91 G28 Z0.(ROTATING TO,", *sconstplname, no_spc$, ")", e$
	  #[if swcsplname <> stoolplname, pbld, "G91 G28 Z0.(FULL RETRACT WHEN ROTATE)", e$]
     pHwear ============> Call out to here
     pCompActive ============> Call out to here
     pCompActive2 ============> Call out to here
#EndRegion
#Region Retract at end of tool path, reference return
pretract        #End of tool path, toolchange
      #"DEBUG: PRETRACT",e$
    if no_nc_out$,
    no_nc_out$ = zero
    z_clear_flg = one
    z_clear = OpClrPlane
      if xform_type,
        bld = zero #Turn off block delete on retract motion
        sm09_0, no_spc$, "(XFORM USED)", e$
     sav_mr6 = zero
      phsm_off
      sav_absinc = absinc$
      absinc$ = one
      sav_coolant = coolant$
      coolant$ = zero
#EndRegion
