How hard will it be to create a custom macro?
Hello Guys,
I maybe given this task today, so I was wondering how hard will it be to create a custom macro to serialize a part 1 through 1000 on a Tornos Screw machine? I will be milling it and I have a y axis. I never wrote a macro before so it will be all new to me so be easy on me please.
THanks
Rob
to me MACROS are very similar to BASIC language, with different punctuation.
i have seen this serializing macro work 20 years ago when i was a noob. (ok more of a noob)
there should be code available where you don't need to re invent the wheel.
i would also be interested to archive the code for my records
Here is my serial macro I use in Okuma's. It could be easily updated for Fanuc. It uses incremental moves for each letter. You position to the bottom left point of the first number then you call the macro. At the end of each letter it positions to the lower left start point for the next letter. The beginning of the macro is the math function to take a 7 place serial number in variable VC5 and break it up into ones, tens, etc in local variables. There is also a variable for depth control. It adds to the serial count at the end of the macro. If the operator needs to rerun a piece he just sets the one variable to the needed serial number and it continues to count from there. I think these are .3 inch tall numbers, I just scales them using NCplot for different applications.
OENGJ
NSTRT
IF [VC5 LT 9999999] NVCHK
NALM1 VUACM[1]='RESET SERIAL'
     VDOUT[992]=1234
NVCHK
MILS=FIX[VC5/1000000]
HNTH=FIX[[VC5-MILS*1000000]/100000]
TNTH=FIX[[VC5-MILS*1000000-HNTH*100000]/10000]
THOU=FIX[[VC5-MILS*1000000-HNTH*100000-TNTH*10000]/1000]
HUNS=FIX[[VC5-MILS*1000000-HNTH*100000-TNTH*10000-THOU*1000]/100]
TENS=FIX[[VC5-MILS*1000000-HNTH*100000-TNTH*10000-THOU*1000-HUNS*100]/10]
WNES=FIX[VC5-MILS*1000000-HNTH*100000-TNTH*10000-THOU*1000-HUNS*100-TENS*10]
NLTR1
IF [MILS NE 1] NLSK1
CALL ONEN1
NLSK1
IF [MILS NE 2] NLSK2
CALL ONEN2
NLSK2
IF [MILS NE 3] NLSK3
CALL ONEN3
NLSK3
IF [MILS NE 4] NLSK4
CALL ONEN4
NLSK4
IF [MILS NE 5] NLSK5
CALL ONEN5
NLSK5
IF [MILS NE 6] NLSK6
CALL ONEN6
NLSK6
IF [MILS NE 7] NLSK7
CALL ONEN7
NLSK7
IF [MILS NE 8] NLSK8
CALL ONEN8
NLSK8
IF [MILS NE 9] NLSK9
CALL ONEN9
NLSK9
IF [MILS NE 0] NLSK10
CALL ONEN0
NLSK10
NLTR2
IF [HNTH NE 1] NLSK11
CALL ONEN1
NLSK11
IF [HNTH NE 2] NLSK12
CALL ONEN2
NLSK12
IF [HNTH NE 3] NLSK13
CALL ONEN3
NLSK13
IF [HNTH NE 4] NLSK14
CALL ONEN4
NLSK14
IF [HNTH NE 5] NLSK15
CALL ONEN5
NLSK15
IF [HNTH NE 6] NLSK16
CALL ONEN6
NLSK16
IF [HNTH NE 7] NLSK17
CALL ONEN7
NLSK17
IF [HNTH NE 8] NLSK18
CALL ONEN8
NLSK18
IF [HNTH NE 9] NLSK19
CALL ONEN9
NLSK19
IF [HNTH NE 0] NLSK20
CALL ONEN0
NLSK20
NLTR3
IF [TNTH NE 1] NLSK21
CALL ONEN1
NLSK21
IF [TNTH NE 2] NLSK22
CALL ONEN2
NLSK22
IF [TNTH NE 3] NLSK23
CALL ONEN3
NLSK23
IF [TNTH NE 4] NLSK24
CALL ONEN4
NLSK24
IF [TNTH NE 5] NLSK25
CALL ONEN5
NLSK25
IF [TNTH NE 6] NLSK26
CALL ONEN6
NLSK26
IF [TNTH NE 7] NLSK27
CALL ONEN7
NLSK27
IF [TNTH NE 8] NLSK28
CALL ONEN8
NLSK28
IF [TNTH NE 9] NLSK29
CALL ONEN9
NLSK29
IF [TNTH NE 0] NLSK30
CALL ONEN0
NLSK30
NLTR4
IF [THOU NE 1] NLSK31
CALL ONEN1
NLSK31
IF [THOU NE 2] NLSK32
CALL ONEN2
NLSK32
IF [THOU NE 3] NLSK33
CALL ONEN3
NLSK33
IF [THOU NE 4] NLSK34
CALL ONEN4
NLSK34
IF [THOU NE 5] NLSK35
CALL ONEN5
NLSK35
IF [THOU NE 6] NLSK36
CALL ONEN6
NLSK36
IF [THOU NE 7] NLSK37
CALL ONEN7
NLSK37
IF [THOU NE 8] NLSK38
CALL ONEN8
NLSK38
IF [THOU NE 9] NLSK39
CALL ONEN9
NLSK39
IF [THOU NE 0] NLSK40
CALL ONEN0
NLSK40
NLTR5
IF [HUNS NE 1] NLSK41
CALL ONEN1
NLSK41
IF [HUNS NE 2] NLSK42
CALL ONEN2
NLSK42
IF [HUNS NE 3] NLSK43
CALL ONEN3
NLSK43
IF [HUNS NE 4] NLSK44
CALL ONEN4
NLSK44
IF [HUNS NE 5] NLSK45
CALL ONEN5
NLSK45
IF [HUNS NE 6] NLSK46
CALL ONEN6
NLSK46
IF [HUNS NE 7] NLSK47
CALL ONEN7
NLSK47
IF [HUNS NE 8] NLSK48
CALL ONEN8
NLSK48
IF [HUNS NE 9] NLSK49
CALL ONEN9
NLSK49
IF [HUNS NE 0] NLSK50
CALL ONEN0
NLSK50
NLTR6
IF [TENS NE 1] NLSK51
CALL ONEN1
NLSK51
IF [TENS NE 2] NLSK52
CALL ONEN2
NLSK52
IF [TENS NE 3] NLSK53
CALL ONEN3
NLSK53
IF [TENS NE 4] NLSK54
CALL ONEN4
NLSK54
IF [TENS NE 5] NLSK55
CALL ONEN5
NLSK55
IF [TENS NE 6] NLSK56
CALL ONEN6
NLSK56
IF [TENS NE 7] NLSK57
CALL ONEN7
NLSK57
IF [TENS NE 8] NLSK58
CALL ONEN8
NLSK58
IF [TENS NE 9] NLSK59
CALL ONEN9
NLSK59
IF [TENS NE 0] NLSK60
CALL ONEN0
NLSK60
NLTR7
IF [WNES NE 1] NLSK61
CALL ONEN1
NLSK61
IF [WNES NE 2] NLSK62
CALL ONEN2
NLSK62
IF [WNES NE 3] NLSK63
CALL ONEN3
NLSK63
IF [WNES NE 4] NLSK64
CALL ONEN4
NLSK64
IF [WNES NE 5] NLSK65
CALL ONEN5
NLSK65
IF [WNES NE 6] NLSK66
CALL ONEN6
NLSK66
IF [WNES NE 7] NLSK67
CALL ONEN7
NLSK67
IF [WNES NE 8] NLSK68
CALL ONEN8
NLSK68
IF [WNES NE 9] NLSK69
CALL ONEN9
NLSK69
IF [WNES NE 0] NLSK70
CALL ONEN0
NLSK70
VC5=VC5+1
RTS
ONEN1
(1)
G91
G1Z-.05-VC6F8.0
X0.125F15.0
G0Z.05+VC6
X-0.0625Y0
G1Z-.05-VC6F8.0
Y0.25F15.0
X-0.0625Y-0.0625
G0Z.05+VC6
X0.1771Y-0.1875
G90
RTS
ONEN2
(2)
G91
X0.125Y0
G1Z-.05-VC6F8.0
X-0.125F15.0
Y0.0625
G2X0.0625Y0.0625I0.0625J0
G3X-0.0625Y0.0625I0J0.0625
G0Z.05+VC6
X0.1771Y-0.1875
G90
RTS
ONEN3
(3)
G91
X0Y0.1875
G1Z-.05-VC6F8.0
G2X0.0625Y-0.0625I0.0625J0F15.0
G1X-0.0156
X0.0156
G2X-0.0625Y-0.0625I0J-0.0625
G0Z.05+VC6
X0.1771Y-0.0625
G90
RTS
ONEN4
(4)
G91
X0.0468Y0.25
G1Z-.05-VC6F8.0
X-0.0468Y-0.1406F15.0
X0.1562
G0Z.05+VC6
X-0.0468Y0.0937
G1Z-.05-VC6F8.0
Y-0.2031F15.0
G0Z.05+VC6
X0.0677Y0
G90
RTS
ONEN5
(5)
G91
X0.1094Y0.25
G1Z-.05-VC6F8.0
X-0.0782F15.0
X-0.0312Y-0.125
X0.0625
G0Z.05+VC6
X0.1771Y-0.0625
G90
RTS
ONEN6
(6)
G91
X0.125Y0.1875
G1Z-.05-VC6F8.0
G3X-0.125Y0I-0.0625J0F15.0
G1Y-0.125
G3X0.0625Y0.0625I0.0625J0
G0Z.05+VC6
X0.1771Y-0.0625
G90
RTS
ONEN7
(7)
G91
X0Y0.25
G1Z-.05-VC6F8.0
X0.1406F15.0
X-0.0782Y-0.25
G0Z.05+VC6
X0.1302Y0
G90
RTS
ONEN8
(8)
G91
X0.0625Y0.125
G1Z-.05-VC6F8.0
G3X0Y-0.125I0J-0.0625F15.0
X0Y0.125I0J0.0625
G2X0Y0.125I0J0.0625
X0Y-0.125I0J-0.0625
G0Z.05+VC6
X0.1146Y-0.125
G90
RTS
ONEN9
(9)
G91
X0Y0.0625
G1Z-.05-VC6F8.0
G3X0.125Y0I0.0625J0F15.0
G1Y0.125
G2X-0.125Y0I-0.0625J0
X0.125Y0I0.0625J0
G0Z.05+VC6
X0.0521Y-0.1875
G90
RTS
ONEN0
(0)
G91
X0Y0.0625
G1Z-.05-VC6F8.0
Y0.125F15.0
G2X0.125Y0I0.0625J0
G1Y-0.125
G1X0.125Y0.125
G0Z.05+VC6
X0.0521Y-0.1875
G90
RTS
here is a B Macro serialization pgm, that This forum hooked me up with, works great on our KIW HMC Fanuc 16 control,
:8200
(SET FEEDRATE FOR PROGRAM)
IF[#9EQ#0]GOTO1
F#9
N1
(DEFAULT DEPTH TO .005 IF NOT SPECIFIED)
IF[#7NE#0]GOTO5
#7=.005
N5
(DEFAULT SPACING TO .2 IF NOT SPECIFIED)
IF[#21NE#0]GOTO10
#21=.2
N10
(SCALE FACTOR)
IF[#11NE#0]GOTO15
#11=.25
N15
#140=#11/.25
(DEFAULT Z IS 0)
IF[#26NE#0]GOTO20
#26=0
N20
(ERROR COMPENSATION VARIABLE)
#149=.001
(FIND NUMBER OF DIGITS)
IF[#19EQ0]GOTO25
#120=FIX[[LN[#19]/2.3026]+1]
N25
IF[#3NE#0]THEN#120=#3
IF[#120NE#0]GOTO30
IF[#19EQ0]THEN#120=1.
N30
#121=1
#122=1
WHILE[#121LE[#120-1]]DO1
#122=FIX[[#122*10]+#149]
#121=FIX[[#121+1]+#149]
END1
(MOVE TO POSITION)
G0G90
X#24Y#25(MOVE TO START X AND Y POSITION)
Z[#26+0.5](MOVE TO SAFE Z POINT)
(START LOOP)
#102=0
N100
G0G90X[#24+[#21*#102]]Y#25
G91
(COUNT DIGITS)
IF[#102LE[#120-1]]GOTO200
G0G91G28Z0
M99
N200
#102=FIX[[#102+1]+#149]
(ISOLATE DIGIT)
#101=FIX[[#19/#122]+#149]
#19=#19-FIX[[#101*#122]+#149]
#122=FIX[[#122/10]+#149]
(CUT DIGIT)
G0G90Z[#26+.05]
IF[#101EQ0]GOTO10
IF[#101EQ1]GOTO11
IF[#101EQ2]GOTO12
IF[#101EQ3]GOTO13
IF[#101EQ4]GOTO14
IF[#101EQ5]GOTO15
IF[#101EQ6]GOTO16
IF[#101EQ7]GOTO17
IF[#101EQ8]GOTO18
IF[#101EQ9]GOTO19
N10(ZERO)
G91G0X-[#140*.0004]Y[#140*.1076]
G90G1Z[#26-#7]
G91G1X[#140*.0176]
G2X[#140*.0374]Y-[#140*.0194]I-[#140*.0021]J-[#140*.05]
X[#140*.0164]Y-[#140*.0417]I-[#140*.0488]J-[#140*.0432]
G1X-[#140*.0009]Y-[#140*.1012]
G2X-[#140*.0157]Y-[#140*.0372]I-[#140*.0527]J[#140*.0004]
X-[#140*.0372]Y-[#140*.0157]I-[#140*.0375]J[#140*.0371]
G1X-[#140*.0353]
G2X-[#140*.0372]Y[#140*.0157]I[#140*.0004]J[#140*.0528]
X-[#140*.0157]Y[#140*.0372]I[#140*.0371]J[#140*.0376]
G1Y[#140*.1059]
G2X[#140*.0157]Y[#140*.0389]I[#140*.0585]J-[#140*.001]
X[#140*.0372]Y[#140*.0175]I[#140*.0382]J-[#140*.033]
G1X[#140*.0177]
G90G0Z[#26+.05]
GOTO100
N11(ONE)
G91G0X-[#140*.0359]Y[#140*.0719]
G90G1Z[#26-#7]
G91X[#140*.0357]Y[#140*.0361]
Y-[#140*.2156]
X-[#140*.0357]
X[#140*.0718]
G90G0Z[#26+.05]
GOTO100
N12(TWO)
G91G0X-[#140*.071]Y[#140*.0531]
G90G1Z[#26-#7]
G91G2X[#140*.0157]Y[#140*.0375]I[#140*.0535]J-[#140*.0004]
X[#140*.0377]Y[#140*.0159]I[#140*.0379]J-[#140*.0371]
G1X[#140*.0352]
G2X[#140*.0375]Y-[#140*.0159]I-[#140*.0005]J-[#140*.0531]
X[#140*.0159]Y-[#140*.0375]I-[#140*.0373]J-[#140*.038]
X-[#140*.0164]Y-[#140*.0383]I-[#140*.0527]J-[#140*.0001]
G1X-[#140*.1256]Y-[#140*.1213]
X[#140*.142]
G90G0Z[#26+.05]
GOTO100
N13(THREE)
G91G0X-[#140*.0605]Y[#140*.0917]
G90G1Z[#26-#7]
G91G2X[#140*.0362]Y[#140*.0159]I[#140*.0366]J-[#140*.0341]
G1X[#140*.034]
G2X[#140*.0357]Y-[#140*.0159]I-[#140*.0006]J-[#140*.0494]
X[#140*.0151]Y-[#140*.0379]I-[#140*.04]J-[#140*.0379]
X-[#140*.0151]Y-[#140*.0379]I-[#140*.0552]
X-[#140*.0357]Y-[#140*.0159]I-[#140*.0363]J[#140*.0335]
X-[#140*.0151]Y-[#140*.0374]I-[#140*.0546]J[#140*.0002]
G1X-[#140*.034]
G2X-[#140*.0362]Y[#140*.0154]I[#140*.0002]J[#140*.0505]
G90G0Z[#26+.05]
GOTO100
N14(FOUR)
G91G0X[#140*.0353]Y-[#140*.1059]
G90G1Z[#26-#7]
G91Y[#140*.2117]
X-[#140*.1059]Y-[#140*.1411]
X[#140*.1412]
G90G0Z[#26+.05]
GOTO100
N15(FIVE)
G91G0X[#140*.0714]Y[#140*.1071]
G90G1Z[#26-#7]
G91X-[#140*.1428]
Y-[#140*.0714]
X[#140*.0895]
G2X[#140*.0374]Y-[#140*.0159]I-[#140*.0005]J-[#140*.0531]
X[#140*.0159]Y-[#140*.0374]I-[#140*.0372]J-[#140*.0379]
G1Y-[#140*.0358]
G2X-[#140*.0159]Y-[#140*.0378]I-[#140*.0537]J[#140*.0003]
X-[#140*.0374]Y-[#140*.0159]I-[#140*.0379]J[#140*.0372]
G1X-[#140*.0357]
G2X-[#140*.0379]Y[#140*.0159]I[#140*.0002]J[#140*.0536]
X-[#140*.0159]Y[#140*.0374]I[#140*.0372]J[#140*.0379]
G90G0Z[#26+.05]
GOTO100
N16(SIX)
G91G0X[#140*.0555]Y[#140*.091]
G90G1Z[#26-#7]
G91G3X-[#140*.0379]Y[#140*.0155]I-[#140*.0376]J-[#140*.038]
G1X-[#140*.0352]
G3X-[#140*.0377]Y-[#140*.0159]I[#140*.0002]J-[#140*.053]
X-[#140*.0157]Y-[#140*.0375]I[#140*.0378]J-[#140*.0379]
G1Y-[#140*.1062]
G3X[#140*.0157]Y-[#140*.0377]I[#140*.0533]J[#140*.0001]
X[#140*.0377]Y-[#140*.0157]I[#140*.0378]J[#140*.0376]
G1X[#140*.0352]
G3X[#140*.0375]Y[#140*.0157]I-[#140*.0004]J[#140*.0535]
X[#140*.0159]Y[#140*.0377]I-[#140*.0371]J[#140*.0379]
G1Y[#140*.0352]
G3X-[#140*.0159]Y[#140*.0375]I-[#140*.0531]J-[#140*.0005]
X-[#140*.0375]Y[#140*.0159]I-[#140*.038]J-[#140*.0372]
G1X-[#140*.0352]
G90G0Z[#26+.05]
GOTO100
N17(SEVEN)
G91G0X-[#140*.0714]Y[#140*.1071]
G90G1Z[#26-#7]
G91X[#140*.1428]
X-[#140*.1071]Y-[#140*.2142]
G90G0Z[#26+.05]
GOTO100
N18(EIGHT)
G91G0X0.Y[#140*.1061]
G90G1Z[#26-#7]
G91X[#140*.0176]
G2X[#140*.0373]Y-[#140*.016]I-[#140*.0004]J-[#140*.0525]
X[#140*.0157]Y-[#140*.0374]I-[#140*.0378]J-[#140*.0378]
X-[#140*.0157]Y-[#140*.0372]I-[#140*.0528]J[#140*.0004]
X-[#140*.0373]Y-[#140*.0157]I-[#140*.0376]J[#140*.0371]
G1X-[#140*.0352]
G3X-[#140*.0373]Y-[#140*.0164]I[#140*.0005]J-[#140*.0519]
X-[#140*.0157]Y-[#140*.0383]I[#140*.0398]J-[#140*.0386]
X[#140*.0159]Y-[#140*.0361]I[#140*.05]J[#140*.0004]
X[#140*.0375]Y-[#140*.0151]I[#140*.0377]J[#140*.0395]
G1X[#140*.0348]
G3X[#140*.0373]Y[#140*.0151]I-[#140*.0001]J[#140*.0539]
X[#140*.0157]Y[#140*.0361]I-[#140*.0346]J[#140*.0365]
X-[#140*.016]Y[#140*.0383]I-[#140*.0551]J-[#140*.0004]
X-[#140*.037]Y[#140*.0164]I-[#140*.0378]J-[#140*.0356]
G1X-[#140*.0352]
G2X-[#140*.0373]Y[#140*.0157]I[#140*.0003]J[#140*.0528]
X[#140*.0157]Y[#140*.0374]I[#140*.0535]J-[#140*.0004]
X[#140*.0373]Y[#140*.016]I[#140*.0377]J-[#140*.0365]
G1X[#140*.0176]
G90G0Z[#26+.05]
GOTO100
N19(NINE)
G91G0X-[#140*.0555]Y-[#140*.091]
G90G1Z[#26-#7]
G91G3X[#140*.0379]Y-[#140*.0155]I[#140*.0376]J[#140*.038]
G1X[#140*.0352]
G1Y[#140*.1062]
G3X-[#140*.0159]Y[#140*.0375]I-[#140*.0532]J-[#140*.0005]
G1X-[#140*.0352]
G1Y-[#140*.0352]
G1X[#140*.0352]
G90G0Z[#26+.05]
GOTO100
M99
  • 2 years later...
Hello Guys,
THanks
Rob
Here is a serialization macro that I wrote about 4-5 years ago. You will have to post each number incrementally and creat a subprogram in the 8100's for each number. If you want to use a different offset for you starting s/n just change #2098 to desired variable.
O8116( S/N MACRO )
( USE OFFSET 98 FOR SERIAL # )
( 00.0001 WILL ENGRAVE 1 )
( 1ST NUMBER )
#138=[#2098*.1]
#140=FIX[#138]
#141=#140+8100.
( 2ND NUMBER )
#138=[#140*10]
#139=FIX[#2098]
#140=#139-#138
#142=#140+8100.
( 3RD NUMBER )
#138=[#139*10]
#139=FIX[#2098*10]
#140=#139-#138
#143=#140+8100.
( 4TH NUMBER )
#138=[#139*10]
#139=FIX[#2098*100]
#140=#139-#138
#144=#140+8100.
( 5TH NUMBER )
#138=[#139*10]
#139=FIX[#2098*1000]
#140=#139-#138
#145=#140+8100.
( 6TH NUMBER )
#138=[#139*10]
#139=FIX[#2098*10000]
#140=#139-#138
#146=#140+8100.
( ARGUMENT )
IF[#141GT8100.]GOTO1
IF[#142GT8100.]GOTO2
IF[#143GT8100.]GOTO3
IF[#144GT8100.]GOTO4
IF[#145GT8100.]GOTO5
IF[#146GT8100.]GOTO6
GOTO100
N1M98P#141
N2M98P#142
N3M98P#143
N4M98P#144
N5M98P#145
N6M98P#146
N100M99
  • 2 years later...
OENGJ
NSTRT
     VDOUT[992]=1234
NVCHK
NLTR1
CALL ONEN1
NLSK1
CALL ONEN2
NLSK2
CALL ONEN3
NLSK3
CALL ONEN4
NLSK4
CALL ONEN5
NLSK5
CALL ONEN6
NLSK6
CALL ONEN7
NLSK7
CALL ONEN8
NLSK8
CALL ONEN9
NLSK9
CALL ONEN0
NLSK10
NLTR2
CALL ONEN1
NLSK11
CALL ONEN2
NLSK12
CALL ONEN3
NLSK13
CALL ONEN4
NLSK14
CALL ONEN5
NLSK15
CALL ONEN6
NLSK16
CALL ONEN7
NLSK17
CALL ONEN8
NLSK18
CALL ONEN9
NLSK19
CALL ONEN0
NLSK20
NLTR3
CALL ONEN1
NLSK21
CALL ONEN2
NLSK22
CALL ONEN3
NLSK23
CALL ONEN4
NLSK24
CALL ONEN5
NLSK25
CALL ONEN6
NLSK26
CALL ONEN7
NLSK27
CALL ONEN8
NLSK28
CALL ONEN9
NLSK29
CALL ONEN0
NLSK30
NLTR4
CALL ONEN1
NLSK31
CALL ONEN2
NLSK32
CALL ONEN3
NLSK33
CALL ONEN4
NLSK34
CALL ONEN5
NLSK35
CALL ONEN6
NLSK36
CALL ONEN7
NLSK37
CALL ONEN8
NLSK38
CALL ONEN9
NLSK39
CALL ONEN0
NLSK40
NLTR5
CALL ONEN1
NLSK41
CALL ONEN2
NLSK42
CALL ONEN3
NLSK43
CALL ONEN4
NLSK44
CALL ONEN5
NLSK45
CALL ONEN6
NLSK46
CALL ONEN7
NLSK47
CALL ONEN8
NLSK48
CALL ONEN9
NLSK49
CALL ONEN0
NLSK50
NLTR6
CALL ONEN1
NLSK51
CALL ONEN2
NLSK52
CALL ONEN3
NLSK53
CALL ONEN4
NLSK54
CALL ONEN5
NLSK55
CALL ONEN6
NLSK56
CALL ONEN7
NLSK57
CALL ONEN8
NLSK58
CALL ONEN9
NLSK59
CALL ONEN0
NLSK60
NLTR7
CALL ONEN1
NLSK61
CALL ONEN2
NLSK62
CALL ONEN3
NLSK63
CALL ONEN4
NLSK64
CALL ONEN5
NLSK65
CALL ONEN6
NLSK66
CALL ONEN7
NLSK67
CALL ONEN8
NLSK68
CALL ONEN9
NLSK69
CALL ONEN0
NLSK70
VC5=VC5+1
RTS
ONEN1
(1)
G91
G1Z-.05-VC6F8.0
X0.125F15.0
G0Z.05+VC6
X-0.0625Y0
G1Z-.05-VC6F8.0
Y0.25F15.0
X-0.0625Y-0.0625
G0Z.05+VC6
X0.1771Y-0.1875
G90
RTS
ONEN2
(2)
G91
X0.125Y0
G1Z-.05-VC6F8.0
X-0.125F15.0
Y0.0625
G0Z.05+VC6
X0.1771Y-0.1875
G90
RTS
ONEN3
(3)
G91
X0Y0.1875
G1Z-.05-VC6F8.0
G1X-0.0156
X0.0156
G0Z.05+VC6
X0.1771Y-0.0625
G90
RTS
ONEN4
(4)
G91
X0.0468Y0.25
G1Z-.05-VC6F8.0
X0.1562
G0Z.05+VC6
X-0.0468Y0.0937
G1Z-.05-VC6F8.0
Y-0.2031F15.0
G0Z.05+VC6
X0.0677Y0
G90
RTS
ONEN5
(5)
G91
X0.1094Y0.25
G1Z-.05-VC6F8.0
X-0.0782F15.0
X-0.0312Y-0.125
X0.0625
G0Z.05+VC6
X0.1771Y-0.0625
G90
RTS
ONEN6
(6)
G91
X0.125Y0.1875
G1Z-.05-VC6F8.0
G1Y-0.125
G0Z.05+VC6
X0.1771Y-0.0625
G90
RTS
ONEN7
(7)
G91
X0Y0.25
G1Z-.05-VC6F8.0
X0.1406F15.0
X-0.0782Y-0.25
G0Z.05+VC6
X0.1302Y0
G90
RTS
ONEN8
(8)
G91
X0.0625Y0.125
G1Z-.05-VC6F8.0
X0Y0.125I0J0.0625
G2X0Y0.125I0J0.0625
X0Y-0.125I0J-0.0625
G0Z.05+VC6
X0.1146Y-0.125
G90
RTS
ONEN9
(9)
G91
X0Y0.0625
G1Z-.05-VC6F8.0
G1Y0.125
X0.125Y0I0.0625J0
G0Z.05+VC6
X0.0521Y-0.1875
G90
RTS
ONEN0
(0)
G91
X0Y0.0625
G1Z-.05-VC6F8.0
Y0.125F15.0
G2X0.125Y0I0.0625J0
G1Y-0.125
G1X0.125Y0.125
G0Z.05+VC6
X0.0521Y-0.1875
G90
RTS
Hello, is this Macro also for a continuos serial ?
THX Sarah
continuous
