I need ideas on how to rough this part.
PAnderson
Good Day Gentlemen,
I do not use Mastercam on a daily basis like most of you do. I am comfortable with it for a lot of things but this one is throwing me for a loop. There are 2 operations in this file and a stock model. Operation 1 is OK but could use a more efficient choice for roughing. I am not up to speed on the best MX can do. Operation 2 is where I am having a problem. No matter what I do, there is a LOT of air cutting and that is unacceptable. Could someone please take a look at this file and point out where I am going wrong or if I am even using the best type of operation.
This is being cut in a 4th/5th axis. A-90 degr., C0. on the first OP and A-90., C180 on the second OP.
Thanks in advance for any help you can give.
Paul
ankle brace2-ck.zip
One of the things you could do to reduce the movement is to set the step downs higher than 10%. The opti tpath is setup to use more of the length of the cutter, 100-150%,  then you would use the step up 10% to semi finish the part. Also if you're running this in TI you should reduce the 45% step over, you should probably be down around 10%
Not certain why it won't trim to the stock model, did you send the file to QC?
