jerms
Renishaw probe multi axis alignment
Good morning all.
We have some parts that we are trying to save....  A little back story, processes were not followed, and/or parts were not inspected. Someone tried to save time by rough drilling the bores in a secondary operation. The drilled holes walked, part was not square and are drilled .015 under finished diameter. We have ±.005 on hole to hole location. The holes have diameter tolerance of .001 and the contour is +.025 stock. I believe it is possible to save the parts if I can get them aligned on the 5 axis. So here we are.
            We are trying to align the part in both A&C axis by probing. I have written a program to probe the two holes, calculate the adjustment angle for C and rotate the offset accordingly Then pick up XY zero again.  Worked great, except I also need to rotate the A axis.  That's where I stopped. I think I would be better off using G68 rotation vs. adjusting the offset. I am not sure if I can use G68 rotation in both A&C axis simultaneously?
Does anyone have experience doing anything similar, would you care to share some insight?   Thank you!
Below is the C axis rotation program if you're curious.
(T1   - RENISHAW - OMP40_A-5000-3712 - H1   - D1   - D0.2362" - R0.1181")
G00G17G20G40G80G90
G91G28Z0.
G28X0.Y0.
G90A0.C0.
N1
(SET XY ZERO IN #1 HOLE)
(OPERATION TYPE - O9823)
T40M06
#5224=90.308(FORCE C SQUARE TO VISE)
(RENISHAW - OMP40_A-5000-3712)
G54G17G90
G00A0.C0.
X0.Y0.
G43H40Z3.25
M165P9832
M165P9810X0.Y0.Z3.25F10.
M165P9810Z2.3768
M165P9823A0.B120.C-120.D.61S1.
M165P9810Z3.25
M165P9833
#800=#135(SETPOINT: CENTER X-AXIS)
#802=#136(SETPOINT: CENTER Y-AXIS)
#138=#138(ACTUAL: DIAMETER)
(MEASURE DISTANCE AND ANGLE OF #2 HOLE)
M165P9832
M165P9810X0.Y3.176Z3.185F50.
M165P9810Z1.8819
M165P9810Z3.185
M165P9833
#801=#135(SETPOINT: CENTER X-AXIS)
#803=#136(SETPOINT: CENTER Y-AXIS)
#139=#139(ACTUAL: DIAMETER)
(ALIGN C AXIS )
IF[#800LT#801]GOTO1
IF[#800GT#801]GOTO2
GOTO100
N1(MOVE G54 C+)
#805=#801-#800(X HOLE 1)
#806=#803-#802(Y HOLE 1)
#530=ATAN[#806]/[#805]
#825=#5224-#530
#5224=#5224-#825
#5224=#5224-.149 (CENTER OF ROTAION COMP)
N2(MOVE G54 C-)
#805=#801-#800(X HOLE 2)
#806=#803-#802(Y HOLE 2)
#825=#530-#5224
#5224=#5224+#825
#5224=#5224+.149 (CENTER OF ROTAION COMP)
N100
(RESET XY ZERO IN #1 HOLE)
G0G54A0.C0.
X0.Y0.
Z3.25
M165P9832
M165P9810Z2.3768
M165P9810Z3.25
M165P9833
M00
M98P3518 (RUN PART )
G49
G91G00G28Z0.
G90A0.C0.
Once you've set your C axis, you can go in and take 2 circles at different depths of a known distance.  Then use trigonometry to calculate the amount of A axis angle to move.  Once moved, pick up your XYZ again.
