MANUAL ENTRY output
sgargaly2
I am programming for a Nakamura MX100 mill turn machine with a B axis upper head and
a lower turret.
The upper head uses a program with a .P1 extension and the lower turret with a .P2 extension.
There are places in Mastercam which I can set upper and lower tools that control which program
the toolpath will be output to.
When I program a "MANUAL ENTRY" data path, the output posts only to the upper head .P1 program.
Is there a method I can use to force the output to the lower turret .P2 program?
This would be helpful for operator and setup instructions at various places in the program as well as inserting
sync codes at specific places.
a lower turret.
I cannot think of a way since Manual entry doesn't use Axis Combinations to control them. Good suggestion for Multi Channel machine. Might go cheat with a point toolpath and use a mi or mr trigger to have it ignore everything, but the comment or use it as a wait point and let the comment of the point toolpath act like your manual entry. You could add Cantext lines and call them from any toolpath, but would need to come up with some common things you want used since Cantext takes already made out comments in the Post and just outputs them.
Here is a section added for Vertical Mill/Turn a couple years ago for a customer to give you an idea.
pcant_out       #Canned text - build the string for output
      #Assign string select type outputs
      if cant_pos < 3, #cant_pos indicates canned text output
        if cantext$ = 3, bld = 1
        if cantext$ = 4, bld = 0
        #Build the cantext string
        #if cantext$ = 1, strcantext = strcantext + sm00
        if cantext$ = 1,
          pbld, pn, sm00, pe #Had to change to keep correct order since comments changed RDB 9-11-19
          pfe
          pfe
          pfe
        if cantext$ = 2, strcantext = strcantext + sm01
        if cantext$ = 5, strcantext = strcantext + scant5
        #if cantext$ = 6, strcantext = strcantext + scomm_str + "SHIM CHECK 1.0" + scomm_end
        if cantext$ = 6, #Added Operator Check Spaces after comment RDB 9-11-19
          pbld, pn, sm00, scomm_str, 'SHIM CHECK 1.0', scomm_end, pe
          pfe
          pfe
          pfe
        #if cantext$ = 7, strcantext = strcantext + scomm_str + "SHIM CHECK .500" + scomm_end
        if cantext$ = 7, #added Operator Check Spaces after comment RDB 9-11-19
          pbld, pn, sm00, scomm_str,'SHIM CHECK .500', scomm_end, pe
          pfe
          pfe
          pfe
        #if cantext$ = 8, strcantext = strcantext + scomm_str + "SHIM CHECK .250" + scomm_end
        if cantext$ = 8, #added Operator Check Spaces after comment RDB 9-11-19
          pbld, pn, sm00, scomm_str,'SHIM CHECK .250', scomm_end, pe
          pfe
          pfe
          pfe
        if cantext$ = 9,
          pbld, pn, sm00, scomm_str,'SHIM CHECK 3.0', scomm_end, pe
          pfe
          pfe
          pfe
        if cantext$ = 10, strcantext = strcantext + "M05"
        if cantext$ = 11, strcantext = strcantext + "M19"
        if cantext$ = 12, strcantext = strcantext + scomm_str + 'HIDE"FAIL SAFE"' + scomm_end
        if cantext$ = 13, strcantext = strcantext + scomm_str + 'SHOW"FAIL SAFE"' + scomm_end
        if cantext$ = 14, strcantext = strcantext + scomm_str + 'HIDE"CLAMP SET 1"' + scomm_end
        if cantext$ = 15, strcantext = strcantext + scomm_str + 'SHOW"CLAMP SET 1"' + scomm_end
        if cantext$ = 16, strcantext = strcantext + scomm_str + 'HIDE"CLAMP SET 2"' + scomm_end
        if cantext$ = 17, strcantext = strcantext + scomm_str + 'SHOW"CLAMP SET 2"' + scomm_end
        if cantext$ = 18, strcantext = strcantext + scomm_str + 'HIDE"CLAMP SET 3"' + scomm_end
        if cantext$ = 19, strcantext = strcantext + scomm_str + 'SHOW"CLAMP SET 3"' + scomm_end
        if cantext$ = 20, strcantext = strcantext + scomm_str + 'HIDE"CLAMP SET 4"' + scomm_end
        if cantext$ = 21, strcantext = strcantext + scomm_str + 'SHOW"CLAMP SET 4"' + scomm_end
        if cantext$ = 22, #added Operator Check Spaces after comment RDB 11-9-2020
          pbld, pn, sm00, scomm_str, 'SHIM CHECK FLUSH', scomm_end, pe
          pfe
          pfe
          pfe
        if cantext$ = 23, strcantext = strcantext + 'M03'
        if cantext$ = 24, strcantext = strcantext + 'M04'
        if cantext$ = 25, strcantext = strcantext + scomm_str + 'REMOVE TOOL' + scomm_end
        if cantext$ = 26, strcantext = strcantext + scomm_str + 'INSTALL TOOL' + scomm_end
        if cantext$ = 27, strcantext = strcantext + scomm_str + 'BROACH_MODE_ON' + scomm_end
        if cantext$ = 28, strcantext = strcantext + scomm_str + 'BROACH_MODE_OFF' + scomm_end
        if cantext$ = 29, #Added REMOVE_HEAD for Vericut RDB 11-7-2020
           pbld, pn, ";REMOVE_HEAD", pe
           pbld, pn, ";REMOVE BACK SPOT FACE TOOL", pe
        if cantext$ = 30, #Added ATTACH_HEAD for Vericut RDB 11-7-2020
           pbld, pn, ";ATTACH_HEAD", pe
           pbld, pn, ";PUT ON BACK SPOT FACE TOOL", pe
        if cantext$ = 31, #Added RPM for Bakcspot face tool process using Contour RBD 11-7-2020
          pbld, pn, "S100 M3", pe
        if cantext$ = 32, #Added RPM for Bakcspot face tool process using Contour RBD 11-7-2020
          pbld, pn, "S100 M4", pe
        if cantext$ = 33, #Added RPM for Bakcspot face tool process using Contour RBD 11-7-2020
          pbld, pn, "S400 M3", pe
        if cantext$ = 34, #Added RPM for Bakcspot face tool process using Contour RBD 11-7-2020
          pbld, pn, "S400 M4", pe
        if cantext$ = 35, #Added RPM for Bakcspot face tool process using Contour RBD 11-7-2020
          pbld, pn, "S500 M3", pe
        if cantext$ = 36, #Added RPM for Bakcspot face tool process using Contour RBD 11-7-2020
          pbld, pn, "S500 M4", pe
        if cantext$ = 37, #Added RPM for Bakcspot face tool process using Contour RBD 11-7-2020
          pbld, pn, "S600 M3", pe
        if cantext$ = 38, #Added RPM for Bakcspot face tool process using Contour RBD 11-7-2020
          pbld, pn, "S600 M4", pe
        if cantext$ = 39, #Added RPM for Bakcspot face tool process using Contour RBD 11-7-2020
          pbld, pn, "S700 M3", pe
        if cantext$ = 40, #Added RPM for Bakcspot face tool process using Contour RBD 11-7-2020
          pbld, pn, "700 M4", pe
        if cantext$ = 41, #Added RPM for Bakcspot face tool process using Contour RBD 11-7-2020
          pbld, pn, "S800 M3", pe
        if cantext$ = 42, #Added RPM for Bakcspot face tool process using Contour RBD 11-7-2020
          pbld, pn, "S800 M4", pe
        if cantext$ = 43, #Added RPM for Bakcspot face tool process using Contour RBD 11-7-2020
          pbld, pn, "S900 M3", pe
        if cantext$ = 44, #Added RPM for Bakcspot face tool process using Contour RBD 11-7-2020
          pbld, pn, "S900 M4", pe
        if cantext$ = 45, #Added RPM for Bakcspot face tool process using Contour RBD 11-7-2020
          pbld, pn, "S1000 M3", pe
        if cantext$ = 46, #Added RPM for Bakcspot face tool process using Contour RBD 11-7-2020
          pbld, pn, "S1000 M4", pe
        if cantext$ = 47, #Added Extrenal Coolant On for Backspot face tool process using Contour RBD 11-7-2020
          pbld, pn, "M73 M08", pe
        if cantext$ = 48, #Added Extrenal Coolant Off for Bakcspot face tool process using Contour RBD 11-7-2020
          pbld, pn, "M09", pe
        if cantext$ > 50,
          strtextno = no2str(cantext$)
          strcantext = strcantext + strm + strtextno
