heidenhain postproccessor
Good morning
I am using a haas umc 500 and 750 psotprocessor to make one of heidenhain also 5 axes.
I already have everything well programmed, but I have a mistake.
In the Haas UMC machine, the B axis rotates about the Y axis and the C axis rotates about the Z axis.
In Heidenhain, on the other hand, it has no B-axis, and the A-axis rotates about the X-axis. The C-axis is the same as in Haas.
My problem is that the machinings come out rotated, as if they were machined along the Y axis, instead of the X axis.
Is there any way to fix this?
Best regards
Your 5-Axis Post makes use of 'rotaxis' and 'rotdir' variables (Rotary Axis and Direction). These are essentially two vectors that are "perpendicular to the axis of rotation".
So, if you want to rotate about "X", you use some combination of Y & Z vectors. If you want to rotate about "Y", you use some combination of X & Z vectors.
There are 3 vector directions (think of them just as "a positive or negative integer value"):
vecx
vecy
vecz
These vector values can also be signed negative:
-vecx
-vecy
-vecz
Change this:
#Secondary axis angle description (in machine base terms)
#With nutating (mtype 3-5) the nutating axis and this plane normal
#are aligned to calculate the secondary angle
rotaxis2$ = vecz  #Zero
rotdir2$  = vecx  #Direction
To this:
rotdir2$  = vecy  #Direction
OR to this:
rotdir2$  = -vecy  #Direction
  • Thanks 2
vecx
vecy
vecz
-vecx
-vecy
-vecz
Change this:
To this:
OR to this:
Thanks Colin!
This is the configuration of the machine
Front A-90 C+0
Back A-90 C+180 or A+90 C+0 o?
Left A-90 C+90
Right A-90 C-90
I've made progress, but I can't get the turns and directions right
#Preferred setup is pri. zero matches sec. zero/direction
#Zero machine and determine the planes perp. to axis rotations
#These plane combinations are valid:
#Primary plane   XY   XZ   YZ
#Secondary or    XZ   XY   XY
#Secondary       YZ   YZ   XZ
#Primary axis angle description (in machine base terms)
#With nutating (mtype 3-5) the nutating axis must be the XY plane
rotaxis1$ = vecy  #Zero
rotdir1$  = vecx #Direction
#NOTE: Use of 'top_map' requires the dealer match the
#      above settings below.  These must match initial settings!!!
p_nut_restore    #Postblock, restores original axis settings
      result = updgbl(rotaxis1$, "vecy") #Zero
      result = updgbl(rotdir1$, "vecx") #Direction
      result = updgbl(rotaxis2$, "vecz") #Zero
      result = updgbl(rotdir2$, "-vecy")  #Direction
1.- L A+50.8636 C-35.5377 R0 F5000.
L X+28.283 Y+31.713 R0 FMAX
Must be A-50.8636
It’s OK L X+28.2826 Y+31.7128 FMAX
2.- L A-31.0027 C-123.6901 R0 F5000.
L X-11.303 Y+76.801 R0 FMAX
Must be C+56.3099
Must be L X+11.303 Y-76.8011 FMAX
3.- L A+90. C-135. R0 F5000.
L X-56.567 Y-88.5 R0 FMAX
Must be C+45
Must be L X+56.5665 Y+88.5 FMAX
4.- L A+90. C+150. R0 F5000.
L X+58.299 Y+89.357 R0 FMAX
Must be C-30
Must be L X-58.2993 Y-89.3569 FMAX
5.- L A-30. C+0. R0 F5000.
L X+95.279 Y-50.979 R0 FMAX
Must be A+30
It’s OK L X+95.2787 Y-50.9788 FMAX
vecx
vecy
vecz
-vecx
-vecy
-vecz
Change this:
To this:
OR to this:
With this information I have managed to make the turns work out well, but now I need to put the XY correctly, it is as if the X were changed by the Y and vice versa
Correct rotations are
Front A-90 C+0
Back A-90 C+180
Right A-90 C-90
Left A-90 C+90
Can someone guide me on how to change the X to the Y?
What are the actual Travel Limits of the Trunnion unit? What is the full stroke of each Rotary axis, plus and minus?
If you are standing at the open machine door, looking at the trunnion table as in your picture, that is the A/C Zero Position, correct?
If you rotate the Tilt Axis +90 degrees, is the Platter (Table/C-Axis) facing you, or facing away?
Always start building your Post with 'pang_output' and 'sang_output' variables, set to "zero". (Normal Angle Output)
pang_output  : 0     #Angle output options, primary
sang_output  : 0     #Angle output options, secondary
                     #0 = Normal angle output
                     #1 = Signed absolute output, 0 - 360
                     #2 = Implied shortest direction absolute output, 0 - 360
I only adjust 'pang_output' and 'sang_output', after I've fixed the Rotation Directions.
If we are standing with the door open, looking at the Trunnion, please confirm the Tilt Axis is along machine X (and X-Positive direction is to the Right). And Positive Y-Axis is going "away from you towards the back of the machine". (I'm just confirming with you that this machine uses a Standard Cartesian Right-Hand Coordinate System.)
When I set up a Post initially, my test file is very simple. Top WCS, and typically 4 of the standard Planes with Drill Operations.
What I want to happen is this >
  • I want the first Operation on a machine that has the Tilt Axis along X, to come from either Top/Front, or Top/Back. This should produce a 90-Degree Tilt Axis Rotation, but no movement of the Platter. (Either A-90 C0., or A+90 C0.)
  • For this to happen, we need to set the Primary Rotary Axis Zero Position to point towards 'vecy' or '-vecy'.
  • For the Secondary (Tilt) Rotary Axis, Zero Position is 'vecz' (positive), and positive direction is either 'vecy' or '-vecy'.
