Tool Inspection point and mi8
So I've been trying to get tool inspection point working.  It seems regardless of what post I start out with (MPMASTER, MPFAN, or the new IKE) if put any value besides 0 in mi8 it will give some form of this error (this one is specifically from the IKE) depending on which post:
21 Aug 2023 08:25:51 AM - RUN TIME -PST(4067,4067)- The value of the string select selection variable is out of range:1011
This seems to point to the "sgcode" string every time regardless of what post is used.  I just can't seem to track down where this could be happening to try to resolve it.
edit:  accidentally posted this in the wrong area.
Have you predefined the variable with a value in the post?
variable      : 0 #Defining the variable with an initial value so the MP language knows it should be used for a math function and not something else.
Example out of MPMASTER.
# Common User-defined Variable Initializations (not switches!)
arctype$    : 2     #CD_VAR Arc center 1=abs, 2=St-Ctr, 3=Ctr-St, 4=unsigned inc.,
                    #5 = R no sign, 6 = R signed neg. over 180
stagetool   : 0     #0 = Do not pre-stage tools, 1 = Stage tools
arccomp     : 0     #Allow for cutter comp to be applied on arc, 0=no, 1=yes
vmc         : 0     #0 = Horizontal Machine, 1 = Vertical Mill
rot_on_x    : 0     #Default Rotary Axis Orientation, See ques. 164.
rot_cw_pos  : 0     #Axis signed dir, 0 = CW positive, 1 = CCW positive
index       : 0     #Use index positioning, 0 = Full Rotary, 1 = Index only
ctable      : 0     #Degrees for each index step with indexing spindle
use_frinv   : 0     #Use Inverse Time Feedrates in 4 Axis, (0 = no, 1 = yes)
rot_type    : 0     #Rotary type - 0=signed continuous, 1=signed absolute, 2=shortest direction
minfeedpm   : 0     #Limit for feed in inch/min
maxfeedpm   : 0     #Limit for feed in inch/min
minfeedpm_m : 0     #Limit for feed in mm/min
maxfeedpm_m : 0     #Limit for feed in mm/min
maxfrdeg    : 0     #Limit for feed in deg/min
the "sgcode" string variable is defined by default in a table.
Example from the IKE post
# Motion G-code selection
sgrap                    : "G00"       #Rapid
sglin                    : "G01"       #Linear feed
sgcw                     : "G02"       #Circular interpolation CW
sgccw                    : "G03"       #Circular interpolation CCW
sgdwell                  : "G04"       #Dwell
sgcode                   : ""
fstrsel sgrap gcode$ sgcode 5 -1
example from MPMASTER
# Motion G code selection
sg00    : "G00"      #Rapid
sg01    : "G01"      #Linear feed
sg02    : "G02"      #Circular interpolation CW
sg03    : "G03"      #Circular interpolation CCW
sg04    : "G04"      #Dwell
sgcode : ""          #Target for string
I think the issue really just stems from somehow it's looking at the NCI 1011 field number which is for misc reals and loading that into the string instead of a gcode value it would understand (0-4 for G00-G04).
