post question on tap cycle output pitch
I have searched thru the forum and this has been covered.  it has not been covered with the logic im seeing below.  anyone see something that jumps out as a possible reason the NC code is outputting an IPM feed rate and not a pitch value?
Switch settings:
fmt  "N" 4  n_tap_thds$  #Number of threads per inch (tpi) / Pitch (mm)
fmt  "F" 2  pitch        #Tap pitch (inches per thread)
Drilling section:
pdrill0$         #Pre-process before drill call
      sav_dgcode = gcode$ #Capture gcode for 5 axis drill
pdrlcommonb     #Canned Drill Cycle common call, before
       if initht$ <> refht$, drillref = zero
       else, drillref = one
      if sav_dgcode = 81,
        result = newfs (two, zinc)
        if tap_feed = one & drillcyc$ = three, result = newfs (two, feed)  #Tap feeds with 4/3 decimal places
        if drillcyc$ = three, drlgsel = fsg1(-ss$) + drillcyc$ * two
        else, drlgsel = fsg2(dwell$) + drillcyc$ * two
        prv_refht_a = c9k
        prv_refht_i = c9k
        prv_dwell$ = zero
      if cuttype = three, sav_dgcode = gcode$
      else, z$ = depth$
      if cuttype = one, prv_zia = initht$ + (rotdia$/two)
      else, prv_zia = refht$  #Fanuc style - G91 Z depth from R level
      #else, prv_zia = initht  #G91 Z depth from initial height
      pcom_moveb
      feed = fr_pos$
      comment$
      pcan
      #5 axis must map the true Z, correct Z calculation here
      if cuttype = three,
        prv_zia = zabs + (-depth$) + initht$
        zia = fmtrnd(zabs)
        zinc = zia - prv_zia
Tapping section:
ptap$            #Canned Tap Cycle
      pdrlcommonb
      #RH/LH based on spindle direction
      if use_pitch, pbld, n$, "G95", e$
      if use_pitch, pbld, n$, "M80", *speed,  e$
      if use_pitch = 1,
        pcan1, pbld, n$, *sgdrlref, *sgdrill, pdrlxy, pfzout, pcout,
          prdrlout, *feed, strcantext, e$
     else,
        if met_tool$, pitch = n_tap_thds$  # Tap pitch (mm  per thread)
        else, pitch = 1/n_tap_thds$       # Tap pitch (inches per thread)
          prdrlout, *pitch, !feed, strcantext, e$
      pcom_movea
      tapflg = 1
4 minutes ago, riverhunter said:
maybe I need to format that before.
Yup, not formatted into your post yet...that's why I asked, some posts have it, some don't...depends on what, where & vintage
In the format section
fmt  "F" 2  pitch       #Tap pitch (units per thread)
under ptap is a good place for this
Here's the complete tap section in my post
ptap$            #Canned Rigid Tapping Cycle
      pdrlcommonb
      result = newfs(17, feed)  # Set for tapping Feedrate format
      if met_tool$,
        if toolismetric, pitch = n_tap_thds$  #Metric NC Code - Metric Tap
        else, pitch = (1/n_tap_thds$) * 25.4  #Metric NC Code - English Tap
      else,
        if toolismetric, pitch = n_tap_thds$ * (1/25.4)  #English NC Code - Metric Tap
        else, pitch = 1/n_tap_thds$           #English NC Code - English Tap
      #pitch = pitch * speed #Force Units Per Minute for regular Tap cycle
      pcan1, pbld, n$, *sgdrlref, *sgdrill, pxout, pyout, pfzout, pcout,
        [if peck1$ > 0, *peck1$], prdrlout, *pitch, strcantext, e$
      result = unforce(feed), !feed
      pcom_movea
im getting an error message, but its pretty vague .
23 Jan 2024 02:17:31 PM - Post processor execution initialized.
23 Jan 2024 02:17:32 PM - Unencrypted input file:
23 Jan 2024 02:17:32 PM - C:\Users\Public\Documents\Shared Mastercam 2024\MILL\POSTS\MP-MATSUURA Fanuc-Hplus-FULL-4TH.pst
23 Jan 2024 02:17:32 PM - Loading input files was successful.
23 Jan 2024 02:17:32 PM - Initialization of pre-defined post variables, strings, postblocks was successful.
23 Jan 2024 02:17:32 PM - Search for defined post variables, strings, postblocks was successful.
23 Jan 2024 02:17:32 PM - Successful completion of post processor execution.
found my error in case anyone search this agian.
      pdrlcommonb
      if use_pitch, pitch = 1/n_tap_thds$              # ***********add this line****************
      if use_pitch = 1,
          prdrlout, *pitch, strcantext, e$                # **********DJF replace *feed with *pitch**********
     else,
      pcom_movea
      tapflg = 1
Just when i thought i had it.......
it handles it fine on the G84 line, but throws an IPM feed on the next position line.  is there a way to stop this?
post code:
      pdrlcommonb
                  if use_pitch, pitch = 1/n_tap_thds$              # DJF add this line
      if use_pitch = 1,
          prdrlout, *pitch, strcantext, e$                # DJF replace *feed with *pitch
     else,
      pcom_movea
      tapflg = 1
nc code:
N190
G91 G28 G00 Z0
G90 G80 G40 G49 G17 G00
(TAP_34_X_2-56_OP5)
M01
T138 M06 (2-56_D3_ROLL_TAP_LOC_0437)
M01
G90G10L12P#517R0
(MAX - Z1.7808)
(MIN - Z.093)
M22 (UNLOCK)
G54
G90 G00 X-.6693 Y4.849 B0. S560 M03
M21 (LOCK)
G43 H#517 Z1.641 M08
T195
G95
M80 S560
G98 G84 X-.6693 Y4.849 Z.443 R.741 F.0179
X.6693 Y4.849 F10.    *************************************here**************
X.6693 Y3.9
X-.6693 Y3.9
X.6693 Y3.142
X-.6693 Y3.142
X-.6874 Y-3.2829
X.6874 Y-3.2829
X.6874 Y-3.9154
X-.6874 Y-3.9154
G80
G94
X5.035 Y.885
Z1.391
G95
M80 S560
G98 G84 X5.035 Y.885 Z.193 R.491 F.0179
X5.035 Y-.885
G80
G94
Z1.7808
ptap when it encounters more than a single hole, then calls out ptap_2$ on subsequent holes, which calls pdrill_2$
ptap_2$          #Canned Tap Cycle
      pdrill_2$
pdrill_2$        #Canned Drill Cycle, additional points
      pdrlcommonb
      pcan1, pbld, n$, pxout, pyout, pzout, pcout, prdrlout, feed, strcantext, e$
      pcom_movea
In all likelihood you'll just need to remove a* from the feed variable
it did not have a * so i added a ! and it seemed to work,  thanks for pointing me in the right direction AGIAN!
      pdrlcommonb
      pcan1, pbld, n$, sgdrlref, pdrlxy, pzout, pcout, prdrlout, dwell$,
        !feed, strcantext, e$                                            #****DJF**** ADDED ! TO FEED 1-24-24
      pcom_movea
