STL machining problem
starn36
Hi everybody,
I have a problem in programming toolpath on stl file. In someplace on the toolpath, the tool plunge on the piece at a random depth go ahead a little bit and return on the surface(triangle)to continue the toolpath. This problem appear in some place on the model. My Stl file is perfect(no holes, the normals are correct).
My model represent a sculture with no flat area. It present a lot a small triangle(30000).
Can you help me to find the problem?
Hello,
Thanks for your response but I used the stl2surf.dll but it's takes about 20 times more time to compute. Remember that my model contains about 20 000 triangles and more. I did a test with a 6000 triangles files and it take 5 minutes with stl2surf.dll and about 15 sec in a the regular way. So I need to know the problem with stl file. Thanks
For the max #tris, i put it at 0. Did you zoom on your toolpath? Did you see some plunge at some area? Did you have spot hole when you do a "verify"?
If your toolpath seems very continious, can you send me you mc9 file? maybe I could find something
