Vacuum formula
Camdude®
Remember that you won't get a perfect vacuum so use a number around 60% of your 14.X psi for safety.
Pumping volume and conductance are key to maintaining vacuum in the presence of any leaks. Even if the pump is adaquate, the plumbing must be large enough to handle volume at low pressure or a small leak could cause the part to release.
+1 to James. The amount of force applied is dependant on #1 the amount of vacuum you can pull (21 to 24 inches of Hg is pretty good - 27 inches and up is considered "high" to "hard" vacuum), #2 the local pressure (which DOES vary from day to day as well as being dependant on your altitude), and #3 the surface area. Using the figures quoted by James provides a reasonable approximation of what you can expect for holding force. Note that the quoted value is at sea level at standard pressure.
1" of Mercury = .49112 PSI
By definition, a pressure that is less than the standard pressure at sea level is considered a vacuum. No wonder it sometimes sucks to live at 6300 feet.....
