t-slot undercut 3axis milling
Markus Roth
Hello Forum,
with search, i found some topics, which helped me to get almost done, what i want. If possible, have a look at tslot-undercut.mc9 on the ftp. It looks pretty nice, but has on the "upper half" of the path some strange retracts, i cant explain myself. Anybody can figure it out?
Also, is it possible to rough this part with the t-slot mill? I tried rough/contour and rough/flowline, but had just no luck, when i applied the settings under gaps/check collision like in my programmed finishing flowline..
best regards,
Markus
Markus
in the same folder have a look on TSLOT-UNDERCUTWTP.ZIP .
I made one rough operation with surface-contour
You can use surface -pocket too with similar approach .
Change settings to your taste ,add needed ammount of offsets to approach according to tool and material ,change settings for tolerance and stepping for finish
enjoy
Winnie teh I can make surface pocket operation too ,but I am busy now ,may be later
Helle Winnieh,
that looks excellent! really! :-)but, if i understand your answer right, then rough/pocket is the only way to rough it? no flowline or contour roughing out this profile from the full material? i had something in mind like the 2dswept and then use the swept2r chook. but there, i have the problem with the gouge of upper half..
best regards,
Markus
Or rough pocket ,or a couple of surface contours with different stock to leave ,or draw simple section ,make contours based on it ,use common contour toolpath to rough materrial and then surface -contour
Be a bit creatibe .
Or look deaper in your flowline parameters and geometry
I can make rough toolpath later ,maybe
rr
