Max arc setting
bogusmill
Thats the setting I'm looking for. we have a Fadal 8030 that doesnt want to machine large radiuses correctly sometimes. I thought it might be in the settings of MC. Our other programer uses a different PC with different settings and I thought it might be MC and not the Fadal. I machined good parts with it today but the other guy wont trust it so he breaks up large arcs to get good parts.
What post are you using??
In the mpmaster you'll find it in the general output settings.
# General Output Settings
spaces : 1 #Number of spaces to add between fields
omitseq : no #Omit sequence numbers?
seqmax : 9999 #Max. sequence number
arcoutput : 0 #0 = IJK, 1 = R no sign, 2 = R signed neg. over 180
arctype : 2 #Arc center 1=abs, 2=St-Ctr, 3=Ctr-St, 4=unsigned inc.
breakarcs : 2 #Break arcs, 0 = no, 1 = quadrants, 2 = 180deg. max arcs
do_full_arc : 0 #Allow full circle output? 0=no, 1=yes
helix_arc : 1 #Support helix arc output, 0=no, 1=all planes, 2=XY plane only
compwarn : 1 #Warn if cutter comp applied on arc, 0=no, 1=yes
maxrad : 999 #Maximum arc radius
hel_2100 : no #Acramatic 2100 style helical moves, 0=no, 1=yes
usecanned : yes #Use canned drilling cycles? Set to no for long output.
force_dpts : no #Force XY output on all drilling lines including cycle call?
wcstype : 2 #0 = G92 at start, 1 = G92 at toolchanges, 2 = G54, 3 = Off
force_wcs : yes #Force WCS output at every toolchange?
stagetool : 0 #0 = Do not pre-stage tools, 1 = Stage tools
tool_table : 1 #Tool table, 0=no, 1=yes, 2=Predator VCNC, 3=MetaCut View
output_z : yes #Output Z Min and Z Max values (yes or no)
cool_zmove : yes #Coolant off with last move
use_pitch : 0 #0 = Use feed for tapping, 1 = Use pitch for tapping
tap_feed : 0 #0 = 2/1 (in/mm) decimal places, 1 = 4/3 (in/mm) decimal places
maxfeedpm : 500 #Limit for feed in inch/min
maxfeedpm_m : 10000 #Limit for feed in mm/min
use_gear : 0 #Output gear selection code, 0=no, 1=yes
max_speed : 10000 #Maximum spindle speed
min_speed : 50 #Minimum spindle speed
sextnc .NC #NC extension override
