Roaming user configurations in MasterCAM 9.1?
stanektool
You mean this???
1. On the desktop, right-click the Mastercam icon whose start-up target you want to customize. Alternatively, choose Start, Run, and then right-click the Mastercam product name.
2. Select Properties. The Properties dialog box appears.
3. Add the name and extension of file to the end of the Target field, leaving a space between the Mastercam.exe string and each file. For example, the Target field could read C:Mcam9Mill9.Exe MYSTARTUP.CFG.
Note: The file name cannot contain spaces.
4. Choose OK. The Properties dialog box closes.
5. Double-click the Mastercam icon you just altered. Mastercam launches the application with the customized configuration file loaded.
Notes:
If multiple users share the same computer, you can set up a unique start-up target for each user. Computers can have multiple shortcuts on the Desktop if all users share the same account, or can have just the shortcuts for the currently logged in user account.
The configuration file should exist in the main Mastercam directory (Mcam9). If you configure your shortcut to use a CFG file that is not in the main Mastercam directory, and you make changes to that CFG file, the system will make a copy of the edited CFG file in your main Mastercam directory instead of using the version from a different location.
