NPT THREADS SINGLE POINT ON LATHE
Increase D to limit the number of passes.
Increase the tool offset to move the tool away from the work to reduce depth of thread or change X to a larger number.
X is the finish root diameter.
D is the first pass depth of cut. (and is used to calculate the remaining pass depths.
I is the taper amount in the .401 length.
In my Mori lathe the pitch would be F.0555
and K would be the depth of thread (which tells the tool where to start calculating the first pass cutting depth).
I do not see the pitch in your code. Should be .0555
