Job setup defaults
Bruce
Version 8
When I use the "Job setup" section in
"Toolpaths" and select a material from the library, this automatically inputs that data in to the contour tool path. My problem is however, why does it only change the feed rate but not the plunge rate or retract rate feeds (they remain the same as set in the "define tool parameters section").
Regard
Bruce
Actualy, when you specify feeds/speeds from material, the plunge rate is calculated at 50% of the feed rate.
I've often wondered(especially recently) where that value comes from. I'm suspecting that it's "hard-coded" in the software. I'd like to be able to specify the plunge feed percentage.
