Latest Patch
Lee.
Hello Everyone, I just tried to install the latest patch, v8addons_full.exe. When I said yes to extract and overwrite I got an error message: Cannot create output file C:mcam81chookslayout.cnt
Does anyone get the same message?
Does anyone have an answer?
Thanks, Lee
Some things to keep in mind when installing the addons patch:
- make certain that Mastercam is not running
- be sure that the path that the patch wants to install to is where Mastercam is installed on your system
- if you're using Windows NT/2000 make sure you have administrative rights (this may not be an issue)
I believe he's trying to install the addons patch and not the update patch.
From http://www.emastercam.com/info/patches/v8/ ...
These files are optional add-ons for Mastercam V8.1.1. The add-ons file will install additional post processors and setup sheets, as well as modified configuration files, new operation defaults, and added drilling operation libraries. The 'without' patches version is reduced in size in order to fit on a floppy disk. The files removed in order to reduce the size are generally non-critical patches.
The directory it's trying to install to is mcam8, I have my program installed in mcam81 and so I re-direct the patch to this directory. Is this ok? Or do I have to re-install everything to mcam8. The program was not running and so i'm confused, please help.
The reason I was installing this in the first place is I'm just trying to stay current.
Advice, Please, Thanks, lee.
If you still receive this error message:
If you already have the Layout C-Hook installed, maybe try renaming all layout.* files something like this:
layout.cnt -> layout.cnt.old
layout.dll -> layout.dll.old
layout.hlp -> layout.hlp.old
layout.txt -> layout.txt.old
Then try to install the addons patch again. If that is succesful, remove the .OLD extensions from the files you renamed. If you don't already have the Layout C-Hook installed, maybe try downloading the patch again. Hopefully some of this will help.
