Verify question
MIL-TFP-41
I am running into a problem with verify leaving LARGE facets on a part...I am using a 4" dia wheel style cutter to cut a 1" diameter (basically the part is round with a square plate on the top & bottom of the part, hence the wheel cutter). The problem I run into is when I tilt the part (5 axis) to do other features with a smaller cutter (3/16 ball) it looks like it is gouging the part or not cutting the part (high spots & low spots with the facets). I am using the highest quality setting in verigy.
Are there any settings to correct this (make the facets smaller)??
JMC
Hopefully someone will correct me if I am wrong. This has been covered before. If you open your verify.prm file, add a line 77, I have mine set to 0.0005 with a space like the rest of the lines. I think this is how I did it.
Someone please correct me if I am wrong. This will also slow down your verify some, but is worth it. You can slide the bar to a couple of notches toward the speed when you want it to be faster and not as accurate.
Glenn
