v9.1 Surface -> chain Question
n23x
Hey Guys,
I'm running into a problem that I've never had before, and I'm sure it something you guys see every day, and know an easy fix, it just has me banghead.gif
I was given a solidworks file to part out, it's simple 2.5D stuff, So I decided to use the create-curve-all edges, delete the surfaces (it's an .IGES file) and just use the 2D geometries. Now whenever I post, I am getting horrifically large posts, and it seems as if each of the geometries have been broken into tiny arcs.
Any easy fixes to this?
Thanks in advance guys!
.jim
An additional note, when I generate the toolpath (should have been the first indication something was wrong) all my arcs show the tool stepping over instead of the start finish that is normally displayed. This, I believe, suggests that the arc was broken up into a series of pieces?
I adjusted the filter, but no luck. I also tried connecting to the FTP site to include the files, but I was unable to connect at the moment. Will try again shortly, or can email if anybody wants to take a look at it.
.jim
One thing you could try, save the file as an iges file from soildworks. Convert the file in mastercam, then try screen bank, unblank, all lines, arcs and splines. You will probably get some lines, arcs, and splins instead of all splines in mastercam. You could then delete the surfaces. After you move or rotate the part, make sure you use screen next menu, combine veiws.
Bruce.
Hey guys, thanks for all the quick responses! Sorry I am slow to respond, but all the help is much appreciated.
Heeler, I'd like to learn how to do this in MC, though that post converter sounds pretty slick.
Italian Stylin', I've been having trouble with the modify>convert to arcs trick. I'm sure it's operator error on my end. Learning to use the little tricks in MC take me FOREVER, it feels like.
Bruce, I really like the unblank trick. I am giving that a try right now!
Thanks a bunch guys!
.jim
Bruce,
The unblank trick seems to be working. When I do the unblank from a freshly imported .IGS, and then remove the surfaces, I am left with good arcs it seems, but it generates these very long lines that run axially though the center of each known arc. Is this normal?
Secondly, what did you mean by the screen>next menu>combine views?
Thanks!
.jim
Is it just one surface or multiples. If it is multiple surfaces you have just created many lines, splines, and arcs on top of each other. This can give you fit when toolpathing using window. You also have to be careful thinking deleting duplicate entities, because many of the splines look identicle but they are not and will give you a fit trying to chain. If it is multiple surfaces I generally have found it safer to create curves one edge, then modify, convert to arcs, all splines and throw a ridiculously small tolerance on it. Gradually increase the tolerance until your actuall part accuracy and machine the splines that are left.
John,
It is multiple surfaces. I have allready run into the duplicate entities issue, so individual create>curve>one edge makes sense.
I guess the big problem that I'm running into, and I'm not sure if I'm conveying this correctly, is:
I have a part which has some very simple geometries, but rather than just redraw it in MC, I'd like to learn how to come up with some 2D contours from the .IGS file. (Simple as in, if I was programing the outer contour, it'd go something like: G01, G02, G03, G02)
The problem that I seem to be getting with these contours is that no solution seems to be seeing all these little splines as the full sized arc, so whenever I post the toolpath it is painfully too large for my Robotool which probably has less ram than my graphing calculater. redface.gif
Like I said, I'm sure this is all boiling down to my vast inexperience in MC, but the help is much appreciated guys. It probably is also not helping that I'm unable to connect to the FTP site here. Though if anybody wants to take a look at it, I'm more than willing to email it out.
.jim
Jim, the method that I told you to try, will unblank all the lines,arc,splines that came with the iges file. The long lines are usually centerlines of the arcs. You may need to delete them, and any other extra unblanked geo.
The other option (if you only need to unblank a few items) is to graphicly only pick the geo that you want to unblank. The "combine views" is useful as sometimes arcs that are created in other software are "flipped" from what mastercam likes. You might notice this if you are chaining geo, and having strange results. John, I have seen what you have indicated with other files, but not if the file is from solidworks. Sometimes you will only get a whole lot of tiny slpines and you may have to create your own geo to reduce the complexity or tedious chaining. Delete duplicate may also help.
Yeah, I only deal with ProE files that I create here inhouse. Pro e has a setting when you export the iges file to bring in the wireframe with the surfaces. Does Solidworks give you that option. Wouldn't a parasolid also give you the wireframe with the surfaces? I don't know I am asking for clarification.
If this is an option reexport the file, or request it from the customer that way. I am not trying to dodge the question, but sometimes there is not a clean easy way to get just the geometry you want.
