SP1 and post issue ?
?Mark
Still have the same problem as in original release, but not sure if it's post or MC issue.
Do we need to update posts again?
EX:
Draw a rectangle, fillet all corners, toolpath contour clockwise starting with a straight line, in toolpath parameters chose multipasses, finish passes 2, spacing 0, lead in/out with a line and tangent arc, enter on first cut, exit on last cut, post
I still get missing G1 code after arc move:
G2X-2.8637Y2.8536R.5
X.3557
Another thing.
Picking arc centers for helical toolpath won't let me specify dia I want to cut (blanked), it defaults to 1.0" arc dia. Is it supposed to be this way?
Kind regards, Mark
Mark, I have been able to duplicate it by setting plunge feed same as cut feed. This is what's happening.
In plinout there the "`" if front of sgcode (`sgcode) tells the post to only output the gcode if something else is also coming out, otherwise hold on to it.
It does keep from outputting, but updates the pprv_gcode$ var which is wrong. I tested by doing:
plinout #Output to NC of linear movement - feed
"JIM-test1",prv_gcode$,e$
pcan1, pbld, n$, sgplane, `sgcode, sgabsinc, pccdia,
pxout, pyout, pzout, feed, strcantext, scoolant, e$
"JIM-test2",prv_gcode$,e$
For now you can take the "`" from in front of the sgcode or set plunge feed dif from cut feed.
You're right Jimmy, setting a diffrent plunge feedrate fixes it, but you get an "ugly" line "G1F__;" between G2 and a next linear move.
Isn't it going to give me a bunch of unnecesary repeats of G1's and G2/3's
Thanks very much for looking into it.
Kind regards, Mark
Thanks Mark for pointing me here!
In this post:
http://www.emastercam.com/ubb/ultimatebb.p...ic;f=1;t=017085
I brought up this same subject, with one addition.
The change in feed rate fixed my situation with alarming out. But, didn't fix the loops in engraving. I get loops on top and bottom of R's (one or the other) and so far on top of P's. Anyone else come across this? Got a fix?
Don't have permission for FTP or I'd put up screenies, code and the MCX file!
