tool pre-setter\gauging program
beej
My okuma has a button style tool presetter on it. right now, we load the tools in the carosel, call up each tool in MDI and run the presetter program on it. (we have to run different programs depending on whether it needs to touch off "on center" or "offcenter"). It seems like there would be a Chook or stand alone program out there I could buy. Or I'm wondering if people are incorporating that into their postprocessors to touch off when the tool is called up.
When I programmed at Boeing using Catia we used a pre defined tool change macro. It sent the machine to /G0 X0.0 Y0.0 after each tool change with spindle off then /M01 with a comment that read (TOUCH TOOL 2.100 FROM SET POINT). They used a 2.100 thingamajig for setting tools. After the first part the operator would turn on block skip and all this would be ignored. You could do this with manual entry in mc very easily if you wanted to. HTH !
Paul,
thanks for the quick response. We have some machines that we do something like that too. But this machine is more automated than that. I'm trying to use this pre-setter that's mounted on the table in such a way that it would take little or no interaction from the operator. There are 2 programs loaded in the machine that we could call up as subprograms or use as templates. in those programs the machine rapids to the presetter, feeds down till it touches. rapids up and then feeds down again. once it touches it sets the length offset automatically.
I'm looking for a program that will run by itself and touch off 10 tools or 15 or 20(whichever we need at the time) while the operator is doing something else.
Ok beej, We use to use a couple diferant ones on our old Hitachi Seiki VMC's. The newer guys don't use them, They just do it the old fashioned way. The programs look like this--
O9001(TOOL SET-M76)
(USE FOR AUTOMATIC )
(MEASURING OF DRILLS,)
(TAPS, SMALL END MILLS)
(TXX M76)
501=14.83
502=-0.5
503=-18.4
G0G80G98M15
G91G30Z0M19
IF[5021EQ501]GOTO1
G28G40X0Y0
N1G30G40Y0
T4120M6
S3000M19
1=4120
[2001+[1*4]]=0
G90G49D0H0
IF[5021EQ501]GOTO2
G91G28X0Y0
GOTO4
N2G91G28Y0
G0Y502
GOTO3
N4G0X501Y502
N3G31Z-16.1F50.0
G4X.25
IF[5023LT-16.]GOTO999
G0G91Z0.125
G31Z-0.15F2.0
G0G91Z0.0156
G31Z-0.02F0.1
G4X1.0
[2001+[1*4]]=5023
G0G91Z2.0
G30Y0Z0
G90
M99
N99G91G30Z0
G90
3000=999(WHERE IS TOOL BLOCK???)
O9002(TOOL SET-M176)
(USE FOR MANUAL MEASURING)
(OF FACE MILLS, BORE BARS)
(TXX M176)
501=14.83
502=-0.5
503=-18.4
G0G80G98M15
G91G30Z0M19
IF[5021EQ501]GOTO1
G28G40X0Y0
N1G30G40Y0
T4120M6
1=4120
[2001+[1*4]]=0
G90G49D0H0
S3000M5
IF[5021EQ501]GOTO2
G91G28X0Y0
GOTO4
N2G91G28Y0
G0Y502
GOTO3
N4G0X501Y502
N3M2
(MEASURE TOOL, PRESS START)
G4X1.
[2001+[1*4]]=5023
G0G91Z2.
G91G30Y0Z0
G90
M99
HTH !
I have done something like this, Being our horizontal has a 240 tool changer. I knew I was going to need to change the macro for setting the tools depending on the diameter. My idea might be a little basic but it works never the less..
Macro #517 offset on our machine is changed by the matsuura side of the control everytime a tool change is had. So with that I can determine what tool is in the head.
Anyhow this can get what you want done with one program, you just have to add in a new section for any specialty tool.
IF[#517EQ1]GOTO1
IF[#517EQ2]GOTO75
IF[#517EQ3]GOTO50
IF[#517EQ4]GOTO50
IF[#517EQ5]GOTO50
IF[#517EQ6]GOTO50
IF[#517EQ7]GOTO1875
IF[#517EQ8]GOTO2
IF[#517EQ9]GOTO125
IF[#517EQ10]GOTO375
IF[#517EQ11]GOTO375
IF[#517EQ12]GOTO25
IF[#517EQ13]GOTO25
IF[#517EQ14]GOTO1875
IF[#517EQ15]GOTO15
IF[#517EQ16]GOTO2
IF[#517EQ17]GOTO1875
IF[#517EQ18]GOTO1875
IF[#517EQ19]GOTO125
IF[#517EQ20]GOTO125
IF[#517EQ21]GOTO25
IF[#517EQ22]GOTO50
IF[#517EQ23]GOTO2
IF[#517EQ24]GOTO2
IF[#517EQ25]GOTO375
IF[#517EQ26]GOTO2
IF[#517EQ27]GOTO2
IF[#517EQ28]GOTO2
IF[#517EQ29]GOTO29
IF[#517EQ30]GOTO60
IF[#517EQ31]GOTO99
IF[#517EQ32]GOTO2
IF[#517EQ33]GOTO2
IF[#517EQ34]GOTO2
IF[#517EQ35]GOTO2
IF[#517EQ36]GOTO2
IF[#517EQ37]GOTO2
IF[#517EQ38]GOTO2
IF[#517EQ39]GOTO2
IF[#517EQ40]GOTO2
IF[#517EQ41]GOTO2
IF[#517EQ42]GOTO2
IF[#517EQ43]GOTO25
IF[#517EQ44]GOTO44
IF[#517EQ45]GOTO25
IF[#517EQ46]GOTO99
IF[#517EQ47]GOTO99
IF[#517EQ48]GOTO2
IF[#517EQ49]GOTO2
IF[#517EQ50]GOTO2
IF[#517EQ51]GOTO2
IF[#517EQ52]GOTO2
IF[#517EQ53]GOTO2
IF[#517EQ54]GOTO2
IF[#517EQ55]GOTO2
IF[#517EQ56]GOTO2
IF[#517EQ57]GOTO75
IF[#517EQ58]GOTO58
IF[#517EQ59]GOTO50
IF[#517EQ60]GOTO1
IF[#517EQ61]GOTO50
IF[#517EQ62]GOTO2
IF[#517EQ63]GOTO2
IF[#517EQ64]GOTO2
IF[#517EQ65]GOTO2
IF[#517EQ66]GOTO2
IF[#517EQ67]GOTO2
IF[#517EQ68]GOTO2
IF[#517EQ69]GOTO2
IF[#517EQ70]GOTO2
IF[#517EQ71]GOTO2
IF[#517EQ72]GOTO2
IF[#517EQ73]GOTO2
IF[#517EQ74]GOTO2
IF[#517EQ75]GOTO2
IF[#517EQ76]GOTO50
IF[#517EQ77]GOTO2
IF[#517EQ78]GOTO2
IF[#517EQ79]GOTO2
IF[#517EQ80]GOTO2
IF[#517EQ81]GOTO2
IF[#517EQ82]GOTO2
IF[#517EQ83]GOTO2
IF[#517EQ84]GOTO2
IF[#517EQ85]GOTO2
IF[#517EQ86]GOTO2
IF[#517EQ87]GOTO2
IF[#517EQ88]GOTO2
IF[#517EQ89]GOTO2
IF[#517EQ90]GOTO2
IF[#517EQ91]GOTO2
IF[#517EQ92]GOTO2
IF[#517EQ93]GOTO2
IF[#517EQ94]GOTO2
IF[#517EQ95]GOTO2
IF[#517EQ96]GOTO2
IF[#517EQ97]GOTO2
IF[#517EQ98]GOTO2
IF[#517EQ99]GOTO2
IF[#517EQ100]GOTO2
IF[#517EQ101]GOTO2
IF[#517EQ102]GOTO2
IF[#517EQ103]GOTO2
IF[#517EQ104]GOTO2
IF[#517EQ105]GOTO2
IF[#517EQ106]GOTO2
IF[#517EQ107]GOTO2
IF[#517EQ108]GOTO2
IF[#517EQ109]GOTO2
IF[#517EQ110]GOTO2
IF[#517EQ111]GOTO2
IF[#517EQ112]GOTO2
IF[#517EQ113]GOTO2
IF[#517EQ114]GOTO2
IF[#517EQ115]GOTO2
IF[#517EQ116]GOTO2
IF[#517EQ117]GOTO2
IF[#517EQ118]GOTO2
IF[#517EQ119]GOTO2
IF[#517EQ120]GOTO2
IF[#517EQ121]GOTO2
IF[#517EQ122]GOTO2
IF[#517EQ123]GOTO2
IF[#517EQ124]GOTO2
IF[#517EQ125]GOTO2
IF[#517EQ126]GOTO2
IF[#517EQ127]GOTO2
IF[#517EQ128]GOTO2
IF[#517EQ129]GOTO2
IF[#517EQ130]GOTO2
IF[#517EQ131]GOTO2
IF[#517EQ132]GOTO2
IF[#517EQ133]GOTO2
IF[#517EQ134]GOTO2
IF[#517EQ135]GOTO2
IF[#517EQ136]GOTO2
IF[#517EQ137]GOTO2
IF[#517EQ138]GOTO2
IF[#517EQ139]GOTO2
IF[#517EQ140]GOTO2
IF[#517EQ141]GOTO2
IF[#517EQ142]GOTO2
IF[#517EQ143]GOTO2
IF[#517EQ144]GOTO2
IF[#517EQ145]GOTO2
IF[#517EQ146]GOTO2
IF[#517EQ147]GOTO2
IF[#517EQ148]GOTO2
IF[#517EQ149]GOTO2
IF[#517EQ150]GOTO2
IF[#517EQ151]GOTO2
IF[#517EQ152]GOTO2
IF[#517EQ153]GOTO2
IF[#517EQ154]GOTO2
IF[#517EQ155]GOTO2
IF[#517EQ156]GOTO2
IF[#517EQ157]GOTO2
IF[#517EQ158]GOTO2
IF[#517EQ159]GOTO2
IF[#517EQ160]GOTO2
IF[#517EQ161]GOTO2
IF[#517EQ162]GOTO2
IF[#517EQ163]GOTO2
IF[#517EQ164]GOTO2
IF[#517EQ165]GOTO2
IF[#517EQ166]GOTO2
IF[#517EQ167]GOTO1
IF[#517EQ168]GOTO2
IF[#517EQ169]GOTO1
IF[#517EQ170]GOTO2
IF[#517EQ171]GOTO2
IF[#517EQ172]GOTO2
IF[#517EQ173]GOTO2
IF[#517EQ174]GOTO2
IF[#517EQ175]GOTO2
IF[#517EQ176]GOTO2
IF[#517EQ177]GOTO2
IF[#517EQ178]GOTO2
IF[#517EQ179]GOTO2
IF[#517EQ180]GOTO2
IF[#517EQ181]GOTO2
IF[#517EQ182]GOTO2
IF[#517EQ183]GOTO2
IF[#517EQ184]GOTO2
IF[#517EQ185]GOTO2
IF[#517EQ186]GOTO2
IF[#517EQ187]GOTO2
IF[#517EQ188]GOTO2
IF[#517EQ189]GOTO2
IF[#517EQ190]GOTO2
IF[#517EQ191]GOTO2
IF[#517EQ192]GOTO2
IF[#517EQ193]GOTO2
IF[#517EQ194]GOTO2
IF[#517EQ195]GOTO2
IF[#517EQ196]GOTO2
IF[#517EQ197]GOTO2
IF[#517EQ198]GOTO2
IF[#517EQ199]GOTO2
IF[#517EQ200]GOTO2
IF[#517EQ201]GOTO2
IF[#517EQ202]GOTO2
IF[#517EQ203]GOTO2
IF[#517EQ204]GOTO2
IF[#517EQ205]GOTO2
IF[#517EQ206]GOTO2
IF[#517EQ207]GOTO2
IF[#517EQ208]GOTO2
IF[#517EQ209]GOTO2
IF[#517EQ210]GOTO2
IF[#517EQ221]GOTO2
IF[#517EQ222]GOTO2
IF[#517EQ223]GOTO2
IF[#517EQ224]GOTO25
IF[#517EQ225]GOTO2
IF[#517EQ226]GOTO2
IF[#517EQ227]GOTO2
IF[#517EQ228]GOTO2
IF[#517EQ229]GOTO2
IF[#517EQ230]GOTO2
IF[#517EQ231]GOTO2
IF[#517EQ232]GOTO2
IF[#517EQ233]GOTO2
IF[#517EQ234]GOTO2
IF[#517EQ235]GOTO2
IF[#517EQ236]GOTO2
IF[#517EQ237]GOTO2
IF[#517EQ238]GOTO2
IF[#517EQ239]GOTO2
IF[#517EQ240]GOTO99
N1(1" ENDMILLS)
M0
G65P9862B1.0T#517Y.45
GOTO30
N75(3/4" ENDMILLS)
M0
G65P9862B1.0T#517Y.325
GOTO30
N50(1/2" ENDMILLS)
M0
G65P9862B1.0T#517Y.22
GOTO30
N375
N50(3/8" ENDMILLS)
M0
G65P9862B1.0T#517Y.125
GOTO30
N25
N50(1/4" ENDMILLS)
M0
GOTO30
N1875
N50(3/16" ENDMILLS)
M0
G65P9862B1.0T#517Y.05
GOTO30
N125(1/8" ENDMILLS)
M0
G65P9862B1.0T#517Y.04
GOTO30
N2(DRILLS AND STRAIGHT ON)
M0
G65P9862B1.0T#517
GOTO30
N15(4.0" FACEMILL)
M0
G65P9862B1.0T#517Y1.5
GOTO30
N29(2.5" FACEMILL)
M0
G65P9862B1.0T#517Y1.0
GOTO30
N60(1.5" FACEMILL)
M0
G65P9862B1.0T#517Y.5
GOTO30
N44
M0
G65P9862B1.0T#517Y.09
GOTO30
N58
M0
G65P9862B1.0T#517Y.6
GOTO30
N30
M99
We use programs that came with our renashal tool setter. It looks like this.
G65 P9853 B1. S.75 T1
There is a lot of macro programs that this program works with. But the "S" number is for tools larger than .375 (the diameter of the stlyes.) and the "T" number is the tool number. The "B" number is for if you just want to set the length is "B1." and length and diameter is "B2." We and using these on Fanuc controls. Also I have a program in the machine that calls out the tool in the spindle then i load the tool i want as T1. It looks like this.
T1 M6
M00
T2 M6
M00
T3 M6
M30
