Instability in toolpath, retracts added? Rotary axis windup issue???
Bruce Caulley
Hello all,
I have managed to work my way around some of the problems I was having with 5 axis surfacing recently, but now that I am posting I have run into a couple of issues.
First: The posted code has several of the following
 105  L X-24.014 Y+17.651 Z-2.028 B+1.152 C+311.892
106 L X-24.037 Y+17.625 Z-2.023 B+.951 C+312.438
107 L X-24.07 Y+17.585 Z-2.017 B+.683 C+312.727
108 L X-24.103 Y+17.545 Z-2.01 B+.415 C+313.51
109 L X-24.137 Y+17.503 Z-2.004 B+.157 C+313.042
110 L X-24.071 Y+17.432 Z+47.996
111 M129
112 L Z-1 F MAX M91
113 L X-495 Y-350 R0 F MAX M91
114 ; INSTABILITY IN TOOLPATH
115 M00
116 TOOL CALL 238 Z S5000
117 CYCL DEF 19.0 WORKING PLANE
118 CYCL DEF 19.1
119 M128
120 L X-24.216 Y+17.506 F MAX ; CLEARANCE FOR TABLE ROTATION
121 L Z+48.002 F MAX ; CLEARANCE FOR TABLE ROTATION
122 L B+.102 C+134.56 F MAX
123 M5
124 L X-24.172 Y+17.461 Z-1.997 F2
125 L X-24.208 Y+17.416 Z-1.991 B+.353 C+135.615
Secondly, the code doesn't appear to be starting in the same C axis position each time it adds a retract. The machine is a DMU 50e and the c-axis limit is set at 30,000 degrees in the control. I was hoping to be able to finish this whole path in one pass, but it would need a c-axis windup of nearly 600,000 degees.
My questions are: What is causing the instability in the post and can I set the post to retract and reset the c-axis once it gets to 30,000???
I will try and do this with a 4 axis path and see if I can play around with the limits on the machine, but any help I can get would be great.
Bruce
If you go vertical in a 5-Axis toolpath, it may result in large C-Axis motion. Vertical has infinite C solutions, but minor tilts in B have only 1 C-Axis solution (there are 2 B solutions +/-, with 1 C solution each).
We check for C motion (inst_lim) in your post. If the C-Axis motion exceeds your inst_lim variable, you get a retract. We also don't feed back down at the same point - we skip the motion from start point to end point of the move that causes the large C-Axis motion. On the Heidenhain, moves are interpolated. If you want the tool in contact during the C-Axis swing, loosen off the inst_lim setting.
