Thread milling multi lead
KTMDAVE
You should start both at 0° ( or the same orientation for both).
Accomodate the number of starts by shifting the start point in Z just like on multi-start threading on a lathe.
Pitch doesn't change.
The shift in Z is (thread lead / # of starts).
For 18 TPI the shift is (0.05555/2) = 0.02777
headscratch.gif I think everyone's right about the pitch angle. That doesn't change. In V9, (something like a mold core) I think you just want to change the start angle?
Might be a bit difficult with a multi-tooth cutter. Trying to accomplish a double thread. We use single tooth cutters. (similar to lathe boring bars).
We have been experimenting blunt starts on the lathe. I have yet to get that perfect.
Oops....
I should have said:
You CAN start both at 0° ( or the same orientation for both).
Accomodate the number of starts by shifting the start point in Z similar to multi-start threading on a lathe.
The shift in Z is (thread LEAD/ # of starts).
For 18 TPI w/2 Starts the shift is (0.11111/2) = 0.05555 .
You enter (2*PITCH)=0.11111 as the helical cut pitch.
The shift in Z by this method eliminates having to rotate the engagement point 180°.
[ 02-21-2006, 09:34 PM: Message edited by: SAIPEM ]
(5/16-18 - 2 START THREAD 1" DEPTH)
(EXTERNAL THREAD MILLING)
(0.375 DIA - SINGLE PT TOOL)
(FIRST START)
G00 X0.4757 Y0.0
Z0.2222
G01 G91 Z-0.0556 F15.0
G01 G41 Y0.1875 F1.5
G03 X-0.1875 Y-0.1875 Z-0.0278 I0.0 J-0.1875
G02 Z-0.1111 I-0.2882 J0.0
G03 X0.1875 Y-0.1875 Z-0.0278 I0.1875 J0.0
G01 G90 G40 Y0.0
G00 Z0.2222
(SECOND START)
G00 X0.4757 Y0.0
Z0.2778
G01 G90 G40 Y0.0
G00 Z0.2778
Chip need to use a single point tool in my opinion. 9 pitch is correct and angle of 180 is correct as well. Can do 4 and 5 leads the same way just need to break your pitch down and start angles down respectfully.
Here is link: Linky
You have to use a single point tool because you'll violate the thread form if you use a multi-tooth thread hob for multi-start threads.
The angle of 180° is only correct if you do NOT shift in Z for each start.
Rotating 180° will cause you to cut a single thread along the same helix if you shift in Z.
BTW, Mike Lynch's example has a big mistake in it.
A 4-16 4-Start Thread has a lead of 0.25" not 0.5" .
He probably meant to call it a 4-8 4-Start Thread.
You still have 8 TPI after all four starts are cut.
In the case of 5/16-18 in the above code, you'll have 18 TPI after both starts are cut.
