Okuma OSP3000L Zero Shift
Mick
Hi there,
Does anyone here have an example Okuma programme utilising the G50 Zero Shift command? I have a local customer having no success with it.
I used to run an old LS-N with an OSP3000L control, and I recall running this feature successfully. I thought I still had the example archived, but it appears I dont anymore :/
If anyone does, if possible, please email a sample to me, at [email protected]
VZOFZ is Okuma's variable definition of Z zero [VZOFX, VZOFC, the list goes on; you get the idea] so you can shift the machine's perception of Z zero by arithmatically manipulating this.
We 'build' Z zero for each job by starting with a known base value [in our case the face of the turret top plate touched off on the face of the spindle] and adding things to it [thickness of the chuck, jaw height, distance from part locating surface to Z zero] to tell the machine where Z zero is located. This allows us to do a lot of things, including using the same TLO for a given tool regardless of where the part is in the machine AND shifting zero to machine multiple parts in one chucking.
Our 'zero set' line in the program looks like this:
VZOFZ=V182+V185+POCF+V1
Where:
V182 is the 'base' number
V185 is the height of the Kitagawa B210 chuck
POCF is a user variable which is the distance from the chuck face to Z zero
V1 is a fudge factor 'global shift' the operator can use if the stock is long / short / etc.
A simple Z zero shift of 1/2" would be:
VZOFZ=VZOFZ-.500
or you could go with:
VZOFZ=V182+V185+POCF+V1-.500
There are more complicated examples that I use and we can talk about those down the line if you are interested.
C
Thanks for the replies guys. It seems the old OSP3000's are a dying breed.
If anyone does come across a G50 work shift example, please send it to me smile.gif
The OSP3000 doesn't have User Task, so that option isn't suitable. But thanks for responding.
Chris,
I have been away a couple days sorry. Right now I use the MC9 Okuma post and modify the program alot. The machine is twin turret but the bottom turret has over .030 runout so i do not use it. In the program I have to recognize both turrets with G14 for the bottom and G13 for the top turret. It can not have any text. The machine needs 4 places past the decimal but can not have a decimal to recognize the deminsions. The machine has 4 gears that go from G41 to G44. I use mostly the higher gears. Any help you could give me would help. PM me if you would like.
Thank you very much,
Matt
The gear range is a G code? That's weird... If you know what the RPM range is for each gear it is simple to modify the post's lookup table to post the correct gear. The no decimal place thing is just a format statement selection, so that's easy. The two-turret thing is beyond my post editing skills, I manually paste together my twin-turret stuff, but it doesn't sound like you use the lower turret anyway [why not fix the alignment?].
Format statements are here:
# Format statements - n=nonmodal, l=leading, t=trailing, i=inc, d=delta
#Default english/metric position format statements
fs2 1 0.7 0.6 #Decimal, absolute, 7 place, default for initialize ( )
fs2 2 0.4 0.3 #Decimal, absolute, 4/3 place
fs2 3 0.4 0.3d #Decimal, delta, 4/3 place
#Common format statements
fs2 4 1 0 1 0 #Integer, not leading
fs2 5 2 0 2 0l #Integer, force two leading
fs2 6 3 0 3 0l #Integer, force three leading
fs2 7 4 0 4 0l #Integer, force four leading
fs2 9 0.1 0.1 #Decimal, absolute, 1 place
fs2 10 0.2 0.2 #Decimal, absolute, 2 place
fs2 11 0.3 0.3 #Decimal, absolute, 3 place
fs2 12 0.4 0.4 #Decimal, absolute, 4 place
fs2 13 0.5 0.5 #Decimal, absolute, 5 place
fs2 14 0.3 0.3d #Decimal, delta, 3 place
fs2 15 0.2 0.1 #Decimal, absolute, 2/1 place
fs2 16 0 4 0 4t #No decimal, absolute, 4 trailing
#Default english/metric feed format statements
fs2 17 0.2 0.1 #Decimal, absolute, 2/1 place
fs2 18 0.4 0.3 #Decimal, absolute, 4/3 place
fs2 19 0.5 0.4 #Decimal, absolute, 5/4 place
fs2 20 1 0 1 0n #Integer, forced output
fs2 21 6 0 6 0l #Integer, six four leading
It sounds like you want 16 [no decimal, abs, 4 trailing] for your X,Y,Z,U,V,W values; you might need to screw around a little with I,J,K,F, etc to get what you want. Those values are set here:
# Toolchange / NC output Variable Formats
fmt T 7 toolno #Tool number
fmt G 4 g_wcs #WCS G address
fmt P 4 p_wcs #WCS P address
fmt S 4 speed #Spindle Speed
fmt M 4 gear #Gear range
fmt S 4 maxss #RPM spindle speed
fmt N 4 n #Sequence number
fmt X 2 x0 #X ZERO position output
fmt X 2 y0 #Y ZERO position output
fmt X 2 z0s #Z ZERO position output
fmt X 2 xabs #X position output
fmt Z 2 zabs #Z position output
fmt U 3 xinc #X position output
fmt V 3 yinc #Y position output
fmt W 3 zinc #Z position output
fmt I 3 iout #Arc center description in X
fmt J 3 jout #Arc center description in Y
fmt K 3 kout #Arc center description in Z
fmt L 2 arcrad #Arc Radius
fmt F 18 feed #Feedrate
fmt F 10 dwell #Dwell
fmt M 5 cantext #Default cantext
For the gear range selection you'll need to change this:
# Define the gear selection code
flktbl 1 3 #Lookup table definition - table no. - no. entries
40 0 #Low gear range
41 400 #Med gear range
42 2250 #Hi gear range
to this:
flktbl 1 4 #Lookup table definition - table no. - no. entries
41 0 #1st gear range
42 500 #2nd gear range
43 1000 #3rd gear range
44 1500 #4th gear range
The RPM stated is where the machine will shift ranges [the bottom of the range for each gear]. Be sure you change the 'number of entries' for the table from 3 to 4 [as I have done in my example] or you'll never get hi gear.
You will also need to change the format statement for gear range to post G instead of M, here:
AND you will need to switch 'usegear' on
