Lathe Ref Points (not G50)....tweak in post?
my87csx481
Hi all.
I know I probably use the mcam reference points in an unorthodox manner but, I like to use the feature to my advantage and preference.
I like to NOT rapid right to the starting point of whatever cycle I am about to use to cut.
Suppose G54 Z zero is the front face of a part and all the part's Z coordinates are negative.
I like to rapid to whatever X diameter and say, absolute Z 1.0", then feed from there to whatever Z coordinate, say Z+.05 at F.1 per rev. The reason for this is the machine's feed override knob does not affect rapid rate....the machine has a seperate rapid overide switch (100%, 50%, 1%). I like to have a little more control the first time through and have that control on a single knob (instead of trying to find the rapid switch).
So my question is: how can I get the move from Z1.0 to Z.05 at a feed rate of .1/rev instead of a rapid move and still maintain the rapid move from home to Z1.0? As crazy as this sounds, I always edit the program and add the G01Z___F.1. It's getting old.
What I get:
T0505
G96G99S600M3
G0X1.89Z1.
Z.05
G71_ _
What I want:
T0505
G96G99S600M3
G0X1.89Z1.
G01Z.05F.1
G71_ _
In V9.1, I could set the default reference points values (I set mine to absolute Z1.0 because I usually use the front face for G54 Z0.0 and I'm comfortable with the 1 inch safety move) and just remember to check the Ref. Points box for every tool I wanted to use them for. You can do it in X also, but it's bugged and it doesn't keep the values after you save it in Machine Def. -> Edit axis combinations -> Reference Points. So I have to key in the Z1.0 for every tool, or: Edit selected operations -> Edit common parameters -> check the ref. points box and key it in once for all tools.
Can this be tweaked in the post? If so, please help me out.
I do know about the rapid moves to maximum feedrate checkbox....but I want the rapid moves to be rapids....I just want the move from mcam reference point to cutting cycle start point to be a feed move.
Sorry for being soooo long winded.
Mike,
If you set Machine Def defaults from "Edit"
in the Operations Manger, they apply to that MCX file ONLY and you'll have to set them every time
you start a new job.
If you want your default edits to stick, you need to do them from the
Machine Type/Machine Def Manager at the top of the screen. Those edits will permanently change
the Machine Defintion.
I can't help you with the post question
