wcs-creating new views
spade117
When creating new views, I notice that after 6 views are used I can't create any more new named views. The "new view window" doesn't pop up after creating a rotated view if you have already used 6 others. Does anyone know a way around this or if I am missing something?
when i want to create the new view....i click on wcs and then rotate...it asks me what axis to rotate around...i put in the #'s i want and hit the green check.....usually a another box will pop open called "new view"......I am not getting that box now. that is my problem.
Ok, I tried to rotate and you are right, the prompt does not come up. I can manually rotate the part and get the prompt to create a new view but, not by specifing a rotation. ???
You can rotate the part from the Gview and then go to WCS and select =Gview to create a new view. This worked for me.
I was trying to copy one that was already made.....I figured out that once you make one at a certain degree rotation, you can't use that same degree again. So instead of having a rotation of 90 and 90...I had to use one of 90 and 89.99.
