Surfacing question.
c-hook
Hey all-
It's been a while since I posted, but here goes...I was wondering if there was a way to set up a surfacing tool path (V9.1) so that it would mill past the surface boundry, in the past I have always just offset the boundries or drawn the part bigger so that the end mill would cut past the edges of the part, sort of a work around, but now I have a part that I don't particularly want to re-draw confused.gif , so any help would be appreciated.
Matt,
Doesn't that only affect the gap ends? For example, if you had a square block with shape on the top and you used a finish parallel cutting at 0 degrees, only the ends in the X axis would be over extended. You would not overlap the part in the Y axis since there is no gap there. Or is the simple fix to use an angle such as 45, which would create gaps all over the part? But what is the surface doesn't lend itself well to a 45 degree cut?
Does that make sense?
Thad
