Mill_Haas_VF
Midwest
# General Output Settings
error_msg$ : 1
err_file$ : 1
sub_level$ : 1 #Enable automatic subprogram support
breakarcs$ : 1 #Break arcs, 0 = no, 1 = quadrants, 2 = 180deg. max arcs
arcoutput$ : 0 #0 = IJK, 1 = R no sign, 2 = R signed neg. over 180
arctype$ : 2 #Arc center 1=abs, 2=St-Ctr, 3=Ctr-St, 4=unsigned inc.
do_full_arc$ : 0 #Allow full circle output? 0=no, 1=yes
helix_arc$ : 2 #Support helix arc output, 0=no, 1=all planes, 2=XY plane only
arccheck$ : 1 #Check for small arcs, convert to linear
atol$ : 0.01 #Angularity tolerance for arccheck = 2
ltol$ : 0.002 #Length tolerance for arccheck = 1
vtol$ : 0.0001#System tolerance
maxfeedpm : 500 #Limit for feed in inch/min
ltol_m : 0.05 #Length tolerance for arccheck = 1, metric
vtol_m : 0.0025#System tolerance, metric
maxfeedpm_m : 10000 #Limit for feed in mm/min
force_wcs : no$ #Force WCS output at every toolchange?
spaces$ : 0 #Number of spaces to add between fields
seqmax$ : 9999 #Max. sequence number
use_gear : 0 #Output gear selection code, 0=no, 1=no
max_speed : 10000 #Maximum spindle speed
min_speed : 50 #Minimum spindle speed
nobrk$ : no$ #Omit breakup of x, y & z rapid moves
progname$ : 1 #Use uppercase for program name (sprogname)
plane$ : 99
______________________________________________
_________________________________________________
pwcs_fanuc #G54+ coordinate setting at toolchange
if wcs_option > one,
if workofs$ <> prv_workofs$ | (force_wcs & toolchng),
if workofs$ > 53, pwcs_fanuc2
else,
if workofs$ < 7,
g_wcs = workofs$ + 53 #10/27 changed from 54 to allow for 1 to equal 54
if workofs$ < 1, g_wcs = 54 #10/27, added to prevent redundant G54 when offset is left at default
*g_wcs
else,
p_wcs = workofs$ - 6
"G54.1", *p_wcs
force_wcs = sav_frc_wcs
!workofs$
Found this section in the post headscratch.gif anything to change here????
I have no idea if this will help, but
Check farther down in the post for force WCS. If your using the mastercamX editor, use the FIND icon and search for forceWCS and see if there is anything there you can change, it looks to be in the peof$ section.
peof$ #End of file for non-zero tool
pretract
if lock_codes = 1 & rot_on_x, pbld, n$, *sunlock, "(UNLOCK)", e$
rotretflg = 1
pbld, n$, "G28", "Y0.", protretinc, e$
rotretflg = 0
if lock_codes = 1 & rot_on_x, pbld, n$, *slock, "(LOCK)", e$
comment$
#Remove pound character to output first tool with staged tools
#if stagetool = one, pbld, n$, *first_tool, e$
n$, *sg90, e$
n$, "M30", e$
mergesub$
clearsub$
mergeaux$
clearaux$
"%", e$
#If posting to Desktop, or other long dir path names, this logic will crash Mastercam
#snci = spathnci + snamenci + sextnci
#sparams1 = ssq + sdq + snci + sdq + sspace + sdq + spathpst + spost1 + sdq + sspace + sdq + spathnc + sdq + ssq
#ppost #Called after posting is complete and all files are closed
#result = fexist(sdll)
#if result = 1, result = dll(sdll,sparams1)
pwcs #G54+ coordinate setting at toolchange
if wcstype = two | wcstype > three,
sav_frc_wcs = force_wcs
if sub_level$, force_wcs = zero
if sav_mi9 = 1, workofs$ = sav_workofs
if workofs$ < 0, workofs$ = 0
if workofs$ < 6,
g_wcs = workofs$ + 54
*g_wcs
else,
p_wcs = workofs$ - five
"G54.1", *p_wcs
!workofs$
check the section towards the bottom of this
I don't know why you would hardcode something like that.
That would seem to me like you are just asking for something to go bad.
It can and should be coded out if that is what you need but hardcoding a workofset in my mind is a bad move.
Midwest,
What about using the Misc Values? The first one should have a "2" in the Misc Integer field. Then just use the Work Offset value of "0" for all the operations. What version are you using? In Mcam X, select all operations and right-click to select the "Edit Selected Ops./Edit Common Parameters". The following dialog shown will allow you to change the Misc Values and Work Offset value in the Planes button for all the ops selected. HTH cheers.gif25zrwbq.jpg
Dave, I'm only using 1 tool plane at a time.
I emailed and found who put the post on the FTP.....they said "The only easy edits for this post are listed at the top of the file as options. The feature you are looking for can be changed, but it is not a simple switch."
Maybe I'll try working some with the "mpmaster post"
If I have to for awhile maybe I'll use the editor to alter all "G54's" to "nothing". rolleyes.gif Don't like this option very well. mad.gif
My old V9 post didn't translate very well to X. Parts of the nc code are not in the proper places in a sample drilling program I have tried.
After I get a post to work.........then I'll start on one for a Hurco. bonk.gifbonk.gif
