Fanuc look ahead question
Thee Dragracer1951
All,
I have been working on adding some of this functionality to mpmaster for everyone to use. I'll be sure to document everything very well so it can be used as a reference. I'm having a problem though.....I don't have a machine.
If you've got some time to help, it will be beneficial to everyone.
Here are a couple of questions that I've got:
1. Anyone here using the new HPCC G05 P10000?
Looking for output format. Pg 78 of the 16/18i manual shows that it can be used along with G05.1.
2. I have seen several different formats for the G05.1 including the following:
Q1 - I have been told that this is for simple interpolation
Q2 - I have been told that this actually filters for arcs in the control and is an additional option.
P/R - Either the P or R address used to determine the acceleration/decceleration characteristics (range from 1-10)
Thanks for the feedback. I'll be adding the Mazak stuff as well.
Brett
Well the G05.1 and G05 P10000 are not used at the same time when I have done it. You have either or from my experience.
The control I have for G05.1 QX sets Q1 turn on AI advanced Preview control/AI Contour Control mode and Q0 truns off AI advanced Preview control/AI Contour Control mode the G05.1 QX.
Where as with G08 PX the P1 turns on Advanced Preview Control On and P0 turn off Advanced Preview Control. Page 378 B-64124EN/01 for the Oi-Mc controls we have.
Now From what I am reading and going to try this wek is that you can use both on with no problem but you have to turn on the G08 1st then the G05.1 if you try ot do it the other way you will alarm out the control.
Email if I can be of more assistance, Also be glad to Beta this stuff for you as well on our Oi controls.
Ron,
Looks good. For the G08 P1 and the G05.1 Q1....yes, turn on the G08 P1 then call G5.1 Q1. Also, both must be activated before G43.
With regards to the HPCC, I got this back from a local guy as well.
G05.1 Q2 is auto filter (for arcs as I had mentioned earlier) and can only run in G5P10000 HPCC mode.
So Q1 is not used with P10000 but if you've got the Q2 option you must call it inside the P10000.
I guess the only thing left before testing is to figure out the accel/decel option (the other optional parameter on that line). Perhaps this is a machine specific thing (it's not in the books that I've got).
Brett
Brett,
If you need any of the Fanuc Control manuals in PDF I've got 15,16,18,21,31, (both T and M and iT and iM as well as 0i both M & T, just let me know what you want and I'll kick them to you.
I've got access to Fanuc Robodrill MATE with an OiMA that is there for me to play with "...if I have time..." and I've always got play time biggrin.giftongue.gif for that kind of thing. It has G8 P1 and G5.1Q1 AI-NANO I or whatever they are calling it this week.
...Perhaps this is a machine specific thing (it's not in the books that I've got)...
Yeah, those settings are machine builder specific.
I don;t believe you can run G8 and G5.1 simultaneously, it's either 1 or the other but not both. Each one has some restrictions too. To be safe anything opcode 3 I don't allow to run with the HSM options.
[ 01-30-2007, 11:01 PM: Message edited by: James Meyette ]
Ok,
I ran the program below and all went well EXCEPT for the last G8P0 cancel. It alarmed out with a "5111 G08 CANNOT BE COMMANDED" Alarm on the LAST cancel.
You HAVE to call G8P1 BEFORE G5.1Q1 or you get the 5111 Alarm.
I am going to create a long program to test if there is a Cycle Time Differential running just G8P1, just G5.1Q1 and running both simultaneously. Also I'll test if incremental is faster than absolute and report the results.
O0001(SAMPLE MAIN)
G0G17G90G80G49G40
G0G91G28Z0
G28X0Y0
G90
G90G52X0Y0Z0
G90G10L2P1X8.080550Y-6.11215Z-12.
G11
M1
N1T1M6
G17
/G8P1
G5.1Q1
G0G54X0Y0S2500M3
G0G43Z5.H1
M98P110
G5.1Q0
/G8P0
G91G28Z0M5
G90G28X0Y0
G49
M01
N2T2M6
G17
G49
/G8P1
G5.1Q1
G0G54X0Y0S2500M3
G0G43Z5.H2
M98P100
G5.1Q0
/G8P0
G91G28Z0M5
G90G28X0Y0
G49
M01
N3T3M6
G49
G8P1
G5.1Q1
G0G54X-4.5Y0S2500M3
G43Z5.H3
M98P101
G5.1Q0
/G8P0
G91G28Z0M5
G90G28X0Y0
G49
M01
N4T4M6
G49
/G8P1
G5.1Q1
G0G54X-4.5Y0.S2500M3
G0G43Z5.H4
M98P101
Q5.1Q0
/G8P0
G91G28Z0M5
G90G28Y0
G49
To say the difference in Performance of G8P1 and G5.1Q1 is stark is being FAR too kind. I'll let the numbers speak for themselves...
Fanuc Oi-MC Control
Programmed Feedrate of 250 IPM
1. NC Program - G5_1Q1ABS.NC
o Cycle Time – 1:27
o File Size - 52 KB
o HSM Algorithm - G5.1Q1
o Absolute Programming (G90)
o Arc Filtering
2. NC Program - G5_1Q1INC.NC
o Cycle Time – 1:27
o File Size – 50 KB
o Incremental Programming (G91)
o Arc Filtering
3. NC Program – G8P1ABS.NC
o Cycle Time – 3:07
o File Size – 52 KB
o HSM Algorithm - G8P1
o Arc Filtering
4. NC Program – G8P1INC.NC
o Cycle Time – 3:07
o File Size – 50 KB
o Arc Filtering
5. NC Program - G5_1Q1ABS-NF.NC
o Cycle Time – 1:47
o File Size – 126 KB
o HSM Algorithm – G5.1Q1
o No Arc Filtering
6. NC Program - G5_1Q1INC-NF.NC
o Cycle Time – 1:47
o File Size – 119 KB
o No Arc Filtering
7. NC Program – G8P1ABS-NF.NC
o Cycle Time – 11:34
o HSM Algorithm – G8P1
o No Arc Filtering
8. NC Program – G8P1INC-NF.NC
o HSM Algorithm – G8PQ1
o No Arc Filtering
9. NC Program – G8P1G5_1Q1ABS-NF.NC
o Cycle Time – 1:47
o HSM Algorithm – G5.1Q1 & G8P1 Simultaneously
o No Arc Filtering
10. NC Program – G8P1G5_1Q1INC-NF.NC
o Cycle Time – 1:47
o No Arc Filtering
