COMMUNICATION TO PROTOTRAK PROBLEMS
Chips Ahoy
I am have trouble communicating to my Prototrak mx3 and mx2. I use Mastercam communicator. I can recieve to my p/c but can't transmit back. I have not try communicating before with these machines. So I don't know if the machine configuration is set right. Baud rate 4800 / Stop bit 1 / data bit 7 / Parity even / Anything else I should know?? confused.gif
Hi Ricky,
I called my friend Steve down the hall 'cuz he uses a Prototak MX3. Steve sez:
Use the Cimco Editor loader. setup a new machine profile using the same baud,stop bits and parity that you described, then....
In the DNC setup dialog got to MACHINE TYPE:
try setting it to:
Generic ISO.
If your getting data into th PC then the com port must be right.
KLG
[ 03-05-2002, 03:55 PM: Message edited by: Keith Graydon ]
Charles,
The MX3 post in mastercam will work for both MX2 and MX3 and outputs a simple G-code..
As far as the comminucations issues.. Mike I know you need to purchase a dongle to do DNC on a prototrack but I don't think you need to upgrade anything to just send ..
Thanks guys for your input.
Mike: Yes there are two post in the Mastercam post file mprotmx2 & mprotmx3.
Charles: You can have a .mx2 or a .cam depending on the button you push to recieve at the machine. No letters and only 8 #s max is right.
Keith: I haven't tried Cimco editor before but if I have to I will next week. I want to be able to do some difficult profiles on these machines and bring them out of the stone age also.
I talked to a man at Southwester Ind. and he said he would fax the step by step process to me Monday so I could get it going.(this past Monday mad.gif ) I am going to pick-up a rs-232 mini tester tomorrow to be sure my cable is correct. Thanks again, Rick wink.gif
We have two of these controls, one 3 axis, the other a 2 axis. The 2 axis requires a feed on each line, but the 2 axis post only will give me a F0. I looked at the logic in the pst. It looks right but its not working
Any Ideas?
Mikee
Hi Ricky:
Here's the db-25 cable pinouts that work for all controls in our shop:
2-------------3
3-------------2
4,5 4,5 (jumper these)
6,8,20 6,8,20 (jumper these)
7-------------7 (optional)
There are many variations on this (I'm sure a lot of people will chime in),
but this works, even though a number of folks have come in and said it will not.
Hope this helps
Ken Nelson (Pebcak Specialist)
By the way, our Prototrak MX 2s have db-25 plugs on the back of the control. smile.gif
