Open pocket starts inside...
William Grizwald
Simple bottle shaped chained 2d curves using "Pocket-Open". The small end is the opening. No matter how I slice it or dice it, the tool wants to plunge into the large area of the pocket then finish at the narrower open end. The tool is a 3/4" EM. The narrow end of the pocket is .875 wide. The widest area is 2.5" across. S/B plenty of room to enter from the narrow area without having to plunge into the part first. What gives?
__________
|----------__________
| * Plunges here ------- <-- Open here
|---------- __________
|________/
Bill
Kannon, The cutting style is locked when using open pocket.
Kyle, Use start point on open pocket gives the "can't cut island boundarys (or somthing like that) which makes sense.
John et all, I sent the file to QC but it's occurred to me that really the purpose of Open Pocket is to allow one to define a pocket boundary with an open side (hence the overlap value adjustment feature). Perhaps it's not designed to nessessarily start at the open end. It's just for selection purposes? We'll see.
Bill
If the "open pocket cutting method" is used, it should start from the open end.
From Help:
Machining open pockets
Open pockets are created from chains that do not have the same start and end point. Mastercam calculates the distance between the start and end points of the chain and treats the chain as if it was closed geometry. For this type of geometry, you can use the Open pocket cutting method, which starts the toolpath at the open end of the pocket and cuts from the inside to the outside. To create an open pocket, select Open from the Pocket type list in the Pocketing parameters tab.
Mike
Bill,
I created a bottle shape similar to yours, using a 3/4 tool, and everything worked fine. On the roughing/finishing parameters page, if zigzag or one way were selected for roughing, it did start on the inside of the pocket. All of the other methods started from outside the boundary. Is this the same issue that you are having?
William
Grizwald,
I believe mcpgmr may be on to something with this statement:
Sometines decreasing the step over amount will fix it too.
If there's a large stepover amount (>50%) and a large stock to leave value, the Open Pocket could simply be entering wherever it finds enough room for the tool. Changing those two values should help as well as using the "Start Point" method described without using the "Open Pocket Roughing" technique.
QC may not consider it a "bug" because the toolpath is simply trying to do what you ask while considering all the values of the parameters. A good test would be to use a smaller diameter tool with the same parameters as the first toolpath. If the smaller tool does it the way you intend, the original tool is too big to do it the same way. HTH cheers.gif
