Agie Wire in X2
Chris Kozell
Anybody out there using an Agie in X2? I am having a Hell of a time trying to get the code right. I keep getting this crazy double move when i change passes. Anyone else run into this?
:110 M62
N110 D01 P01 S01 T01 G43
N120 G01 X-005080 Y+000000 G44
N130 G01 X+000000 Y-058420 G40
N140 G03 X+005080 Y-005080 I+005080 J+000000 G44
N150 G01 X+127000 Y+000000
N160 G01 X+000000 Y+254000
N170 G01 X-254000 Y+000000
N180 G01 X+000000 Y-254000
N190 G01 X+127000 Y+000000
N200 G03 X+005080 Y+005080 I+000000 J+005080
N210 G01 X-005080 Y+000000 G44
N220 G01 X-010000
N230 G01 X+000000 Y+058420 G40
N240 G45
N250 M62
N260 G01 X+000000 Y+061000 G40 M22 (BAD!!!)
N270 G01 X+000000 Y-061000 M22 (BAD!!!!)
:280 M62 .
N280 D02 P02 S02 T02 G43
Z0 has to be the top.
Open up Mastercam help and search for the word Agie and read the rules. (I think there is a French version.)
Toolpath Tips
For the Agievision control, we recommend that a part's zero position be on top. You then define geometry as negative from the Z=0 plane.
Before running agie.dll, define your stock in the machine group's Stock setup option. If you do not define your stock, agie.dll warns that the path requires stock dimensions. You will then be unable to complete the toolpath.
When window selecting chains, if each contour needs separate settings, set Mastercam to generate separate operations.
Mastercam gets the Measure point from the Start position at the first tool only. (Start Point means Measure Point in Agie terms.) The Auto start position check box in the Lead in/out tab of the toolpath's parameters dialog box controls this option. Normally, you should disable Auto start position so that Mastercam writes the start point to the output.
Events are created for Stop (SERP), but not for Glue Stop, so tabs do not create the event unless stop is selected in NC Parameters.
Set Misc Values 7 to 2
MI7 - At radius smaller than offset (0=off, 1=undercut, 2=no undercut)
