Y Axis Machining
Greg Williams
Hi Guys,
We have a Sachman RP3 machine with a Heidenhian 422 controller, This machine has a universal head (the same deal as Huron, Correa and pacfic to name a few) With this machine like most bed mills the Z travel is greater that the Y travel so hence we do most of our machining on angle plates with the head rotated so that the Y axis is into the job (as in a horizoltal machine), Now to achieve the correct G code I have always done the following
1, drawn the job in the top veiw
2, do my toolpaths as normal
3, create a NCI file and rotate it 90 degress
4, Post that rotated NCI file
I do it this way because I first started using Mastercam with version 5 and that is how I did it back then.
Now with this being the year 2002 there must be a better way,
How do you folks do it?
PS I have V9 Level 3
Greg
This is the start and end sequence we use.
0 BEGIN PGM TEST MM
1 ; PROGRAM NAME - T
2 ; DATE-22-03-02 TIME-13:31
3 ; 10MM ENDMILL ROUGH
4 TOOL CALL 1 Z S15000
5 CYCL DEF 7.0 DATUM SHIFT
6 CYCL DEF 7.1 # 0
7 L B+0 C+0 R0 F MAX
8 CYCL DEF 10.0 ROTATION
9 CYCL DEF 10.1 ROT 0
16 L Z+100 R0 F MAX
17 CYCL DEF 7.0 DATUM SHIFT
18 CYCL DEF 7.1 # 0
19 CYCL DEF 10.0 ROTATION
20 CYCL DEF 10.1 ROT 0
21 M05
99999 END PGM TEST MM
Cheers
