Filter or not to filter?
Rob_Bish
I've only ran scallop not high speed scallop, but I do as Paul does 2:1 with my total tolerance set to .001 or less for finishing. If I don't have a lot of memory and I am roughing I set my total tolerance to a higher number. It creates less code and most of the time I can get away with a less accurate toolpath on my rough opeation.
Justin
James,
Does a non filtered finishing toolpath give a better surface finish than a filtered toolpath when using HPCC from a dada server?
If so why is this?
I would have thought any arc in the gcode would be a smother motion on the machine than small point to point moves even under HPCC.
Point to point will always be more accurate.
There are always slight deiviations on circular interpolation depending on your tolerances set.
On the new HPCC controls, they filter the point to point for you that is why you do not need to use a filter in MC.
That is why you get the better finish on a Robodrill because of the "nano interpolation".. wink.gif
These controls look as much as 500 blocks ahead blend the point to point paths into a smooth spline just like Mastercam's filter.
[ 05-02-2007, 09:26 AM: Message edited by: Murlin ]
Take a simple surface finsh contour of a internal cone shape for example.
If I use filter I get arcs in the XY plane, if I don't the gcode is all point to point moves.
The filtered toolpath is much shorter and it verifies in Vericut and MC's verify much much quicker.
If the control is going to take the point to point moves and create arcs anyway why not do it in MC?
Depends on your machine, we have some OKK's 2 VM5's and a VM900 with the Neomatic control. I got a bad finish once filting out surfacing op and I have not used it since. When running from the machines hard drive memory is nearly limitless anyway. I might turn the filter on to make the path verify or regen faster but I always turn it off before I post.
Here's some results for the various Look Ahead Styles ...
To say the difference in Performance of G8P1 and G5.1Q1 is stark is being FAR too kind. I'll let the numbers speak for themselves...
Fanuc Robodrill MATE
Fanuc Oi-MC Control
Programmed Feedrate of 250 IPM
1. NC Program - G5_1Q1ABS.NC
o Cycle Time – 1:27
o File Size - 52 KB
o HSM Algorithm - G5.1Q1
o Absolute Programming (G90)
o Arc Filtering
2. NC Program - G5_1Q1INC.NC
o Cycle Time – 1:27
o File Size – 50 KB
o Incremental Programming (G91)
o Arc Filtering
3. NC Program – G8P1ABS.NC
o Cycle Time – 3:07
o File Size – 52 KB
o HSM Algorithm - G8P1
o Arc Filtering
4. NC Program – G8P1INC.NC
o Cycle Time – 3:07
o File Size – 50 KB
o Arc Filtering
5. NC Program - G5_1Q1ABS-NF.NC
o Cycle Time – 1:47
o File Size – 126 KB
o HSM Algorithm – G5.1Q1
o No Arc Filtering
6. NC Program - G5_1Q1INC-NF.NC
o Cycle Time – 1:47
o File Size – 119 KB
o No Arc Filtering
7. NC Program – G8P1ABS-NF.NC
o Cycle Time – 11:34
o HSM Algorithm – G8P1
o No Arc Filtering
8. NC Program – G8P1INC-NF.NC
o HSM Algorithm – G8PQ1
o No Arc Filtering
9. NC Program – G8P1G5_1Q1ABS-NF.NC
o Cycle Time – 1:47
o HSM Algorithm – G5.1Q1 & G8P1 Simultaneously
o No Arc Filtering
10. NC Program – G8P1G5_1Q1INC-NF.NC
o Cycle Time – 1:47
o No Arc Filtering
