Forcing Long Hand Drilling Cycles
Mick
I have a C Axis VTL lathe post, with a Fanuc control. The drill cycles are limited, and as a result, we want to force the peck drilling cycle to be output longhand.
I've tried setting the Peck Drilling cycle enable to off in the Control Definition, and have also set the "usecannedpeck" or whatever variable it is ( smile.gif ), but it still forces out the peck drill cycle. Is there something I am missing here?
I tried forcing all the drill cycles to off, but they still output.
Ok, scrub that last query. It helps to check which post you are editing, and which post you are using......
ARRGGH...LOL
Interestingly though, when I disabled it in the control definition, it didn't disable the drill cycles. They were still output as cycles. However, when I edited the post, they were output as longhand.
The Control Definition simply sets the initial value of various predefined variables (such as usecanpeck$). These values are then occasionally overwritten in the post processor inside of a post block.
An example of this would be in MPLFAN:
pdrill0$         #Pre-drill postblock call
if cuttype = five, #Don't allow 5 axis, rests at toolchange
usecandrill$ = zero
usecanpeck$ = zero
usecanchip$ = zero
usecantap$ = zero
usecanbore1$ = zero
usecanbore2$ = zero
usecanmisc1$ = zero
usecanmisc2$ = zero
In this case, canned cycle output is disabled no matter what the CD setting is if you are doing a 5-axis toolpath.
This is not really tied to whether the post is an "X" post or an updated pre-X post. It is simply due to the fact that in the end, the code in the post determines the output.
