Lathe B axis question
dan m
I put a file on the ftp site called baxis it's in the MCX2_Files folder. what I am tring to do is turn the b axis on the lathe (which i have never done ) to the proper angle and just cut the chamfer on the holes. I think I am haveing a problem creating the proper construction plain. any help would be greatly appreciated.
Yes you are creating the wrong C-plane for this operation. I do not know your machine but if it like the Integrex you can not go very far below center line so not only do you need to get the B axis correct you need to get the C axis to index to the next place everytime.
Step by step is how I do this on the Integrex.
1: go to the right view this will be your 1st index and should put the B axis at the right direction which should be B0 is that is normal for your machine if down is normal the I would think it would B-90. Ok now you have your B axis in the correct place to chamfer this hole.
2a: Use Transform and rotate the operation to the other places so you have 2 operations to do the whole thing complete. Now I have seen posts want move to the X,Y places to do this and if this happens go to 2b. if not you are good.
2b: Make a C-plane for each hole and you must do this in right if you try to rotate your C-planes from the top View it does not work and will keep giving you Front or Back and not change like it should so go to right and do it this way. Ok so go to plane/rotate planes/ then in the Z box put in 60. Now you will get the new C-plane box and name that what ever you choose. Me I like 60 Deg and then you will do the same for each hole. Then copy your operation and then in each copy just use that new C-lane for each index and all should post correct for you.
Now MpLfan will not give you a B axis, but here is code from our Integrex Post using Transform:
(PROGRAM NAME - DANSBTEST DATE=DD-MM-YY - 12-06-07 TIME=HH:MM - 14:57 )
(PROGRAMMER - RON B)
(POST LICENSE - V&M PRECISION)
(T1 | UNDEFINED TOOL NAME | DIA. - 1 | SUFFIX - 0.)
G20 G49 G69 G80 G40 G17 G90 G94
M205
N1
(TOOLPATH GROUP - TOOLPATH GROUP-1)
G20 G10.9 X0
G91 G28 X0.
G28 Z0.
T00000001 T1 M06
G91 G28 X0. Z0.
G90
M200
M212
G94 G0 G54 C0. <------ C index
M210
M108
G0 B0. <-------- B index
M107
G97 S7000 M03
G0 G17 G43 P1 H1 X1.5784 Z.3524
Y1.5696
G1 X1.6105 Y1.6079 F.01
X1.5875 Y1.6271 Z.2378
X1.5617 Y1.6412 Z.2405
X1.5332 Y1.65 Z.2453
X1.5038 Y1.653 Z.2518
X1.4746 Y1.6503 Z.2598
X1.4464 Y1.6418 Z.2693
X1.4208 Y1.6282 Z.2795
X1.398 Y1.6097 Z.2906
X1.3796 Y1.5876 Z.3017
X1.3656 Y1.5621 Z.3127
X1.3569 Y1.5344 Z.3232
X1.3536 Y1.5056 Z.3325
X1.3561 Y1.4749 Z.3407
X1.3596 Y1.4606 Z.3446
X1.3639 Y1.4486 Z.3473
X1.3783 Y1.4206 Z.3508
X1.3898 Y1.4049 Z.3524
X1.4057 Y1.3899 Z.3521
X1.4196 Y1.3791 Z.3511
X1.445 Y1.3653 Z.3479
X1.4734 Y1.3566 Z.342
X1.5025 Y1.3535 Z.3343
X1.532 Y1.3564 Z.3248
X1.5598 Y1.3646 Z.3145
X1.5856 Y1.3782 Z.3035
X1.6082 Y1.3965 Z.2923
X1.6267 Y1.4186 Z.2814
X1.6416 Y1.4455 Z.2709
X1.6464 Y1.4589 Z.2653
X1.6496 Y1.471 Z.2607
X1.653 Y1.501 Z.2532
X1.6505 Y1.5314 Z.2465
X1.647 Y1.5458 Z.2433
X1.6427 Y1.5581 Z.241
X1.6289 Y1.5848 Z.2382
X1.6105 Y1.6079 Z.237
X1.5227 Y1.6511 Z.2476
X1.5176 Y1.6014
Z.4524 F0.
G55
M212
G0 C60. <-------------C index
M210
X1.5784 Y1.5696 Z.3524
X1.5176 Y1.6014
Z.4524 F0.
G56
M212
G0 C120. <-------------- C index
M210
X1.5176 Y1.6014
Z.4524 F0.
G57
M212
G0 C180. <---------- C Index
M210
X1.5176 Y1.6014
Z.4524 F0.
G58
M212
G0 C240. <----- C index
M210
X1.5176 Y1.6014
Z.4524 F0.
G59
M212
G0 C300. <----------- C index
M210
X1.5176 Y1.6014
Z.4524 F0.
M212
G91 G28 X0.
G28 Z0. M05
G90
M01
G28 Y0.
M30
Ron thanks for the help. that will work just fine I was just wondering how you would do it cocking the b axis 13 degress and doing it. The only reason i wanted to do it that way is because we have only worked at b-90 and b0 after having the machine 2 years i figured i would try somthing different manly tring to learn somthing new. thanks for all your help. cheers.gif
Ok well you did not have the holes at 13 degree and that edge is conical so was not thinking along those lines. I have a new file with the holes at 13deg s oyou get a better idea how to do this. It is called Baxis Crazy 13.mcx.
Here is the posted code:
(PROGRAM NAME - BAXIS_CRAZY_13 DATE=DD-MM-YY - 12-06-07 TIME=HH:MM - 16:55 )
(T2 | 1/2 INCH DRILL | DIA. - 0 | SUFFIX - 2.)
(T1 | 1/2 CHAMFER MILL | DIA. - 0 | SUFFIX - 2.)
M205
N1
G20 G10.9 X0
G91 G30 P3 X0.
G30 P3 Z0.
T2.02 T1 M06
G91 G30 P3 X0. Z0.
G90
M200
M212
G94 G0 G54 C105.
M108
G0 B13.
M107
G97 S1000 M03
G68 X0. Y0. Z0. I0. J1. K0. R13.
G0 G17 G43 X1.8279 Z2.
Y0.
G98 G81 Z.2 R1.2 J.1 F10. M212
G80
G0 C165.
G0 X1.8279 Z2.
Y0.
G80
G0 C225.
G0 X1.8279 Z2.
Y0.
G80
G0 C285.
G0 X1.8279 Z2.
Y0.
G80
G0 C345.
G0 X1.8279 Z2.
Y0.
G80
G0 C45.
G0 X1.8279 Z2.
Y0.
G98 G81 Z.7283 R1.2 J.1 F10. M212
G80
G69
G91 G30 P3 X0.
G30 P3 Z0. M05
G90
M01
N2
(TOOLPATH GROUP - BAXIS_CRAZY_13)
G20 G10.9 X0
G91 G30 P3 X0.
G30 P3 Z0.
T1.02 T2 M06
G91 G30 P3 X0. Z0.
G90
M200
G94 G0 G54 C105.
M108
G0 B13.
M107
G97 S5000 M03
G0 G17 G43 X1.8802 Z2.
Y-.0864
Z1.1902
G1 Z1.0152 F10.
X1.9477 Y-.1601
X1.9768 Y-.1335 Z1.0163
X1.9999 Y-.1021 Z1.0169
X2.0165 Y-.0664 Z1.0174
X2.0258 Y-.0284 Z1.0177
X2.0276 Y.0107
X2.0216 Y.0496 Z1.0176
X2.0083 Y.0862 Z1.0172
X1.9879 Y.12 Z1.0166
X1.961 Y.1493 Z1.0159
X1.9292 Y.1723 Z1.0153
X1.8944 Y.1886 Z1.0148
X1.8565 Y.1979 Z1.0144
X1.8165 Y.1997 Z1.0143
X1.7778 Y.1935 Z1.0144
X1.7409 Y.1801 Z1.0148
X1.7173 Y.1671 Z1.0152
X1.6946 Y.1487 Z1.0157
X1.6776 Y.1318 Z1.0161
X1.6555 Y.1011 Z1.0168
X1.6393 Y.0663 Z1.0173
X1.6299 Y.0284 Z1.0177
X1.6283 Y-.011
X1.6341 Y-.0495 Z1.0175
X1.6476 Y-.0865 Z1.017
X1.6679 Y-.1199 Z1.0164
X1.6943 Y-.1488 Z1.0157
X1.726 Y-.1721 Z1.015
X1.7614 Y-.1886 Z1.0146
X1.7997 Y-.198 Z1.0143
X1.8395 Y-.1997
X1.8782 Y-.1935 Z1.0146
X1.9143 Y-.1803 Z1.015
X1.9477 Y-.1601 Z1.0156
X2.009 Y-.0825 Z1.0172
X1.9184 Y-.0402
G0 Z2.
G0 C165.
G0 X1.7866 Z2.
Y-.0913
Z1.1891
G1 Z1.0141
X1.7545 Y-.186
X1.7731 Y-.1923 Z1.0138
X1.8117 Y-.1993 Z1.0136
X1.851 Y-.1986 Z1.0138
X1.8891 Y-.1903 Z1.0141
X1.9252 Y-.1747 Z1.0146
X1.9573 Y-.1524 Z1.0152
X1.9846 Y-.1242 Z1.0159
X2.0058 Y-.0913 Z1.0165
X2.0202 Y-.0549 Z1.0169
X2.0272 Y-.0162 Z1.0171
X2.0278 Y.0034
X2.0265 Y.0229
X2.0182 Y.0613 Z1.0168
X2.0026 Y.0972 Z1.0164
X1.9803 Y.1294 Z1.0158
X1.9521 Y.1567 Z1.0151
X1.9364 Y.1679 Z1.0148
X1.918 Y.1783 Z1.0145
X1.8886 Y.191 Z1.0141
X1.8645 Y.1966 Z1.0138
X1.8244 Y.1999 Z1.0137
X1.7854 Y.1954
X1.7482 Y.1834 Z1.0141
X1.7139 Y.1642 Z1.0146
X1.6841 Y.1389 Z1.0153
X1.6597 Y.1081 Z1.016
X1.6419 Y.0733 Z1.0166
X1.6312 Y.0356 Z1.017
X1.628 Y-.0036 Z1.0171
X1.6325 Y-.0423 Z1.0169
X1.6446 Y-.0798 Z1.0165
X1.6636 Y-.1139 Z1.0159
X1.689 Y-.1438 Z1.0152
X1.7197 Y-.1682 Z1.0145
X1.7545 Y-.186 Z1.014
X1.7923 Y-.1968 Z1.0137
X1.8117 Y-.1993
X1.8312 Y-.1999
X1.8527 Y-.1983 Z1.0138
X1.8363 Y-.0997
G0 Z2.
G0 C225.
G0 X1.7278 Z2.
Y.0049
Z1.1922
G1 Z1.0172
X1.628 Y-.0001
X1.6289 Y-.0197
X1.6366 Y-.0581 Z1.0169
X1.6517 Y-.0944 Z1.0163
X1.6734 Y-.1269 Z1.0157
X1.7012 Y-.1547 Z1.015
X1.7337 Y-.1764 Z1.0144
X1.7699 Y-.1914 Z1.0139
X1.8084 Y-.199 Z1.0137
X1.8475 Z1.0138
X1.886 Y-.1913 Z1.0142
X1.9222 Y-.1763 Z1.0147
X1.9548 Y-.1545 Z1.0153
X1.9825 Y-.1268 Z1.0159
X2.0042 Y-.0943 Z1.0165
X2.0193 Y-.058 Z1.0169
X2.0239 Y-.0392 Z1.0171
X2.0268 Y-.0183 Z1.0172
X2.0278 Y.0137
X2.0242 Y.0382 Z1.0171
X2.0125 Y.0767 Z1.0168
X1.994 Y.1113 Z1.0162
X1.9692 Y.1415 Z1.0156
X1.9387 Y.1664 Z1.015
X1.9043 Y.1848 Z1.0144
X1.8667 Y.1961 Z1.014
X1.8277 Y.1999 Z1.0138
X1.7888 Y.1961
X1.7512 Y.1846 Z1.0141
X1.7168 Y.1662 Z1.0146
X1.6864 Y.1412 Z1.0153
X1.6616 Y.111 Z1.016
X1.6431 Y.0764 Z1.0166
X1.6318 Y.0388 Z1.0171
X1.628 Y-.0001 Z1.0172
X1.6318 Y-.0392 Z1.0171
X1.6432 Y-.0766 Z1.0166
X1.6526 Y-.0959 Z1.0163
X1.7383 Y-.0445
G0 Z2.
G0 C285.
G0 X1.7966 Z2.
Y.0953
Z1.1891
G1 Z1.0141
X1.7553 Y.1863
X1.7365 Y.1778 Z1.0139
X1.7036 Y.1566 Z1.0145
X1.6754 Y.1293 Z1.0152
X1.6531 Y.0971 Z1.0159
X1.6375 Y.0611 Z1.0164
X1.6293 Y.0228 Z1.0167
X1.6286 Y-.0164 Z1.0168
X1.6357 Y-.0549 Z1.0165
X1.65 Y-.0913 Z1.016
X1.6713 Y-.1243 Z1.0153
X1.6985 Y-.1524 Z1.0146
X1.7308 Y-.1748 Z1.014
X1.7667 Y-.1903 Z1.0135
X1.805 Y-.1986 Z1.0133
X1.8443 Y-.1993 Z1.0134
X1.8634 Y-.1967 Z1.0135
X1.8839 Y-.1917 Z1.0137
X1.9141 Y-.1809 Z1.0141
X1.9356 Y-.1685 Z1.0145
X1.9671 Y-.1435 Z1.0151
X1.9924 Y-.1136 Z1.0158
X2.0114 Y-.0794 Z1.0163
X2.0234 Y-.042 Z1.0166
X2.0278 Y-.0032 Z1.0168
X2.0246 Y.036 Z1.0167
X2.0138 Y.0736 Z1.0164
X1.9959 Y.1084 Z1.0159
X1.9714 Y.1392 Z1.0152
X1.9417 Y.1644 Z1.0146
X1.9073 Y.1835 Z1.014
X1.87 Y.1954 Z1.0136
X1.8311 Y.1999 Z1.0133
X1.8119 Y.1993
X1.7929 Y.1968 Z1.0134
X1.7553 Y.1863 Z1.0136
X1.7194 Y.168 Z1.0142
X1.6889 Y.1437 Z1.0148
X1.6749 Y.1286 Z1.0152
X1.7542 Y.0678
G0 Z2.
G0 C345.
G0 X1.8926 Z2.
Y.0765
Z1.1902
G1 Z1.0152
X1.9493 Y.1589
X1.933 Y.1701 Z1.0154
X1.8979 Y.1873 Z1.0148
X1.8599 Y.1974 Z1.0144
X1.8209 Y.1998 Z1.0143
X1.782 Y.1946 Z1.0144
X1.745 Y.1819 Z1.0147
X1.711 Y.1622 Z1.0153
X1.6817 Y.1363 Z1.016
X1.6579 Y.1052 Z1.0167
X1.6406 Y.07 Z1.0173
X1.6306 Y.0322 Z1.0176
X1.6281 Y-.007 Z1.0177
X1.6333 Y-.0458 Z1.0175
X1.646 Y-.0829 Z1.0171
X1.6657 Y-.1168 Z1.0164
X1.6777 Y-.1319 Z1.0161
X1.6926 Y-.1469 Z1.0157
X1.7174 Y-.1672 Z1.0152
X1.7391 Y-.1792 Z1.0148
X1.7768 Y-.1933 Z1.0144
X1.8155 Y-.1996 Z1.0143
X1.8545 Y-.1982 Z1.0144
X1.8928 Y-.1891 Z1.0148
X1.9283 Y-.1729 Z1.0153
X1.9602 Y-.1499 Z1.0159
X1.9869 Y-.1212 Z1.0166
X2.0075 Y-.088 Z1.0171
X2.0212 Y-.0511 Z1.0175
X2.0274 Y-.0126 Z1.0177
X2.0277 Y.0071
X2.0261 Y.0267
X2.0171 Y.0648 Z1.0174
X2.0008 Y.1004 Z1.017
X1.9778 Y.1323 Z1.0164
X1.9493 Y.1589 Z1.0157
X1.9158 Y.1796 Z1.0151
X1.8792 Y.1932 Z1.0146
X1.8581 Y.1976 Z1.0144
X1.847 Y.0982
G0 Z2.
G0 C45.
G0 X1.928 Z2.
Y-.0059
Z1.1922
G1 Z1.0172
X2.0279 Y-.0009
X2.0269 Y.0197
X2.0192 Y.0581 Z1.0169
X2.0042 Y.0944 Z1.0165
X1.9824 Y.1269 Z1.0159
X1.9546 Y.1547 Z1.0153
X1.9221 Y.1764 Z1.0147
X1.8859 Y.1914 Z1.0141
X1.8474 Y.199 Z1.0138
X1.8083 Z1.0137
X1.7698 Y.1913 Z1.0139
X1.7336 Y.1763 Z1.0144
X1.701 Y.1545 Z1.015
X1.6733 Y.1268 Z1.0157
X1.6516 Y.0943 Z1.0163
X1.6366 Y.058 Z1.0169
X1.6319 Y.0392 Z1.0171
X1.629 Y.0183 Z1.0172
X1.628 Y-.0137
X1.6316 Y-.0382 Z1.0171
X1.6433 Y-.0767 Z1.0166
X1.6618 Y-.1113 Z1.016
X1.6866 Y-.1415 Z1.0153
X1.7171 Y-.1664 Z1.0146
X1.7515 Y-.1848 Z1.0141
X1.7891 Y-.1961 Z1.0138
X1.8281 Y-.1999
X1.867 Y-.1961 Z1.014
X1.9046 Y-.1846 Z1.0144
X1.9391 Y-.1662 Z1.015
X1.9694 Y-.1412 Z1.0156
X1.9942 Y-.111 Z1.0162
X2.0127 Y-.0764 Z1.0168
X2.0238 Y-.0398 Z1.0171
X2.0279 Y-.0009 Z1.0172
X2.024 Y.0392 Z1.0171
X2.0126 Y.0766 Z1.0168
X2.0037 Y.0951 Z1.0165
X1.918 Y.0436
G0 Z2.
G69
G91 G30 P3 X0.
G30 P3 Z0. M05
G90
G30 P3 Y0.
M30
What you do it use the Hole Axis chook to create the arc and lines. Then you use the line as your Cplane. To od this you go to planes/planes by normal. Then a box will come up with an arrows to choose which C-Plane you want.(Thing to remember here is that you are using C-planes not WCS even though when you hit Planes all of the standard views have (WCS next to them) I commented many times this should no be, but I am crazy). Ok now remember you want Z facing you and X pointing in a good direction which if you think about how you are looking at the part if oyu were looking at the View X should be facing the same as if you were in the Top View. Sometimes when you use Normal for the C-plane selection it is off in X so then you rotate that C-plane around Z to the way you want it facing and that should take car of any index problems if your index comes out below X0. Hope that was clear enough to understand and follow.
