HAVING TROUBLE WITH THE HTML SETUP SHEET.
Jeff2005
When you run the .exe to install it pops up for you.
HTML Setup Sheet Template - Mastercam X2
This product launches in the application associated with HTML files.
It is intended for use with Mastercam X2.
Mill, Lathe, and Router products are supported, including Mill/Turn applications.
1. Run the .exe file to install to your root Mastercam directory
(e.g. C:Mcamx2).
2. Under Settings, Configuration, Toolpaths, Setup sheet program, select .SET File
3 Set all of your Control Definitions to use HTML.set as your Setup sheet template
under the Files Control topic. You'll have to also set this in the active
Control Definition for all existing MCX files.
4. Modify your Control Definitions to output parameter information
such as 'stock left' by enabling the 'Write NC Operation information'
check box under the NC parameter file area of the Files Control topic.
Open your html.set and check
#Root Mastercam location
sroot "C:mcamx"
Some versions contain that. (newer versions set that based on the location of mp.dll).
It needs to match your install directory.
You also need to have supporting files like
C:mcamx2chookshtml_launch.exe
and
If the setup sheet can't find the launcher app, nothing will pop up after creation.
