path curve not smooth
Ray H.
The curves are generated by saving the toolpath geometry when using a surface contour toolpath with depth cuts set to abs. and (0 min & 0 max) depths. I then tel the tool to have a 5 degree draft and .0005 tip diameter. Thia gives me the tangent geometry if I were to cut the part with a 5 degree endnill. So the curves are already broken into maybe 100 pieces and there isn't a drastic arc curve or sharp corner area anywhere.
What I was trying to do was Create a solid larger than the profle and then do a sweep cut solid.Using the geo from the toolpath as a swept path. After creating geometry that represents the 5 degree draft endmill.
