Mazatrol Letter Suffix Output for Mazaks.
crazy^millman
If you are using the In-House post they use mr2 to control the suffix output for the post. They use .01 and the machine understands that a A. However if you have an operator that does not fully understand this it can cause problems. I added this to our post.
"MAZATROL SUFFIX - ", prdbsuffix_abc,
add this to the ptoolcomment section for the post you are using as well as the ptooltable section. It may be in the psb section of the post so need to talk to In-House or your dealer if a dealer supplied post and locked up.
add this to the bottom of the same section:
prdbsuffix_abc
if mr2$ = 0, ".00"
if mr2$ = .01, *stra
if mr2$ = .02, *strb
if mr2$ = .03, *strc
if mr2$ = .04, *strd
if mr2$ = .05, *stre
if mr2$ = .06, *strf
if mr2$ = .07, *strg
if mr2$ = .08, *strh
if mr2$ = .09, *strj
if mr2$ = .11, *strk
if mr2$ = .12, *strl
if mr2$ = .13, *strm
if mr2$ = .14, *strn
if mr2$ = .15, *strp
if mr2$ = .16, *strq
if mr2$ = .17, *strr
if mr2$ = .18, *strs
if mr2$ = .19, *strt
if mr2$ = .21, *stru
if mr2$ = .22, *strv
if mr2$ = .23, *strw
if mr2$ = .24, *strx
if mr2$ = .25, *stry
if mr2$ = .26, *strz
if mr2$ = .61, *sheavy, *stra
if mr2$ = .62, *sheavy, *strb
if mr2$ = .63, *sheavy, *strc
if mr2$ = .64, *sheavy, *strd
if mr2$ = .65, *sheavy, *stre
if mr2$ = .66, *sheavy, *strf
if mr2$ = .67, *sheavy, *strg
if mr2$ = .68, *sheavy, *strh
if mr2$ = .69, *sheavy, *strj
if mr2$ = .71, *sheavy, *strk
if mr2$ = .72, *sheavy, *strl
if mr2$ = .73, *sheavy, *strm
if mr2$ = .74, *sheavy, *strn
if mr2$ = .75, *sheavy, *strp
if mr2$ = .76, *sheavy, *strq
if mr2$ = .77, *sheavy, *strr
if mr2$ = .78, *sheavy, *strs
if mr2$ = .79, *sheavy, *strt
if mr2$ = .81, *sheavy, *stru
if mr2$ = .82, *sheavy, *strv
if mr2$ = .83, *sheavy, *strw
if mr2$ = .84, *sheavy, *strx
if mr2$ = .85, *sheavy, *stry
if mr2$ = .86, *sheavy, *strz
In your string definitions need to define the following:
strg        "G"     #String for address G
strn "N" #String for address N
strt "T" #String for address T
strv "V" #String for address V
sheavy "HEAVY " #String for Heavy Tools in Mazatrol
Here is how the posted code looks like:
(T20 |  3" FACE MILL                  |  EIA SUFFIX - .06 | MAZATROL SUFFIX - F)
(T21 | 3/4 FLAT ENDMILL | EIA SUFFIX - .05 | MAZATROL SUFFIX - E)
(T22 | 5/8 DRILL | EIA SUFFIX - .04 | MAZATROL SUFFIX - D)
(T15 | ID ROUGH MIN. .5 DIA. - 80 DEG. | EIA SUFFIX - .17 | MAZATROL SUFFIX - R)
(T16 | ID FINISH MIN. .5 DIA. - 80 DEG. | EIA SUFFIX - .06 | MAZATROL SUFFIX - F)
(T17 | ID GROOVE - MIN. .25 DIA. | EIA SUFFIX - .07 | MAZATROL SUFFIX - G)
(T1 | OD ROUGH RIGHT - 80 DEG. | EIA SUFFIX - .17 | MAZATROL SUFFIX - R)
(T2 | OD FINISH RIGHT - 35 DEG. | EIA SUFFIX - .06 | MAZATROL SUFFIX - F)
(T27 | 1/2 FLAT ENDMILL | EIA SUFFIX - .05 | MAZATROL SUFFIX - E)
(T23 | 1/4 CENTERDRILL | EIA SUFFIX - .03 | MAZATROL SUFFIX - C)
(T24 | LTR. B DRILL | EIA SUFFIX - .04 | MAZATROL SUFFIX - D)
(T25 | 3/16 FLAT ENDMILL | EIA SUFFIX - .05 | MAZATROL SUFFIX - E)
(T26 | 1/2 COUNTERSINK | EIA SUFFIX - .03 | MAZATROL SUFFIX - C)
G20 G49 G69 G80 G40 G17 G90 G94
M205
N1
G20 G10.9 X0
G91 G30 P3 X0.
G30 P3 Z0.
G30 P3 B0.
T20.06 T21 M06
G91 G30 P3 X0. Z0.
