post help - custom drill cycles
YoDoug®
I am modifying a lathe post to use custom drill cycles for part probing. I have three cycles set up for custom 9,10,11. the output is just about what I need, what I am having trouble is getting the labels inside of the toolpath on the custom drill parameters to say "diameter", "print", etc.
TIA
Which parameters Doug?
Those labels are handled down in the text section of the X posts.
If it is on the custom parameters tab
you'll have to add in the labels something like this
[drill cycle 10 custom parameters]
1. "ID PROBE PARAMETERS"
2. ""
3. ""
4. ""
5. ""
6. ""
7. "(S) HOLE SIZE"
8. "(W) WORK OFFSET"
9. ""
10. ""
11. ""
I added this and there is no change.
[drill cycle 9 custom parameters]
1. "DIAMETER TO MEASURE"
2. "VARIABLE NO TO STORE THE POSITION ERROR"
3. "TOLERANCE = H.001 = +/-.001"
4. "VARIABLE NO TO STORE THE ERROR"
5. "STYLUS OVERTRAVEL"
6. "THE RADIUS OF THE FEATURE FOR OFFCENTER FEATURES"
7. "SPINDLE ORIENTATION FOR MEASURE"
8. "TOOL NO TO BE UPDATED"
9. "UPPER LIMIT ERROR AMOUNT"
10."PRINT, 1.0 PRINT W/O HEADER, 2.0 PRINT W HEADER"
I also tried changing the text in the control def and no change with that either
You'll need to "reload" the machine def to pick up the changes.
also,
if you have multiple control def inside of the text section, you might check to make sure you edited the one for that machine.
Where it lists the control
[CTRL_MILL|HAAS_3AX__MPMASTER]
Are they on here?
# Enable Canned Drill Cycle Postblocks, set for mill and lathe
pcuttypldrl #Change cut parameters for lathe drill
usecandrill$ = 0
usecanpeck$ = 0
usecanchip$ = 1
usecantap$ = 1
usecanbore1$ = 0
usecanbore2$ = 0
usecanmisc1$ = 0
usecanmisc2$ = 0
Mail Doug.
For some reason which I cannot put my hands on it just would NOT see your section.
I went into the control def >> text section and named a custom cycle, this in turn created a new control def reference in your post. I then copied all of your stuff into the new reference, deleted the old and all is now well.
I've seen small spelling errors cause problems when naming by hand but yours was named exactly the same as the new created one, so I am sort of stumped as to the why but it is now fissed
Thanks John, It looks great. I just added description info for the other 2 probe cycles and they are showing up as should.
I still have some more testing before I can release this to my other programmers. If I come across anything else weird I will post.
